Results 1 to 4 of 4
Thread: Bucks or stutters while under load
    Member jrhende6's Avatar
    Dec 2017
    Tucson, AZ
    48
    Default Bucks or stutters while under load
    Replaced plugs, rotor, cap, timing chain and fuel injectors.
    Set timing to 10 BTDC, calibrated TPS to 1V and did the TV pressure adjustment using the easy method.
    Car runs smooth but bucks or stutters at various speeds and loads. A perfect example is when driving on level highway at 65MPH she is smooth. But when grade changes to a slight grade the car begins to buck/stutter/jerk.
    Any ideas?
    If you have an analog volt meter check the tps full sweep. Also check all your grounds.
    39,270
    are your plug wires routed properly? If you have the 7 and 8 wires run right next to one another it can cross-fire and do this. Those want to be spaced apart as much as possible.
    Dec 2017
    Tucson, AZ
    48
    Amazing. That helped a lot. Never thought it could happen. Inductance.
    Now there is a very faint stutter and she idles rough. May be I'll go after codes now.
