Results 1 to 12 of 12
Thread: Setting Alignment
    Default Setting Alignment
    Last week I replaced my steering box with a Cardone 276555, I also replaced the pitman arm, both inner tie rods, outers and sleeves, I then set the alignment using the string method, once completed I had the steering wheel slightly to the right (barely noticeable) The next day I set the alignment at work using our John Bean alignment machine, I set the steering wheel straight and adjusted as necessary, once I completed this my steering wheel was significantly to the left, (while test driving) I tried a few more times, but I just couldn't get it centred. I've also replaced the rag joint and idler arm last year and I know the front end of the car is tight, and all the hardware for the items replaced are properly tightened. Any advice on what to do next would be appreciated, thanks
    39,252
    sounds like maybe your alignment machine is full of beans. If this is one of those deals that tells you when the wheel is straight based on the toe sweep, maybe ignore that each time you do it and set the wheel where it goes. Fix the toe as needed to make the car go down the road correctly.
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,146
    Did you use the tool to "lock" the steering wheel straight when putting it on the alignment machine ?
    Another possibility in the the steering box. With my 96 CV. even after alignment and it being straight coming off the rack, the wheel would not be straight very soon afterward. Replacing the steering box with a Red Head box fixed that plus other problems. Cardone boxes have not proven to be great quality. My mechanic is on box #4 on his Surburban. Only reason he keeps using Cardone is it is under warranty.
    I tried with the steering wheel lock tool and with my coworker sitting in my car holding the steering wheel, im sure if I try it again I can get it better, but I dont see it being perfect. Also do they make better Steering boxes for these vehicles, like the red head steering boxes? If so send me a link.
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,146
    Just go to Redhead steering gears.com Go to the rebuilding tab on the top of the page. Send them a request for a quote. They may have one in stock. They did not show your application on the site. Same with when I needed mine. When I sent a request they had one in stock. If they do not, they take your box and rebuild it.
    I am very pleased. Fast turn around prompt refund of the core charge. Return shipping label enclosed. Just follow all instructions that are included. Smooth transaction. Steering box works very well. 1 year warranty.
    39,252
    How sloppy is the steering box on it? if there is a lot of of dead steering wheel action and its not a problem in the linkages, that could explain it.
    Tom, can they do custom rebuilds? I don't need one, but just thinking if they could use the stiffer torsion bar from a later one in a stock 80s gear that would be great. I'm not a big fan of the over-boosted feel that 80s models had. Mine has a really nice 01 CVPI box but most of those are slapped out by now and it requires steering shaft and line mods to make it fit. If a stock box could be made to have better wheel feel and require zero modifications I'd call that a big win.
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,146
    Gadget, You might email or call them. They seem pretty decent people to deal with. I think they just rebuild however they might do a custom job. I know when I emailed them I got a call the next day by not a office clerk but someone who knows how the job is done. We did the deal right over the phone.
    39,252
    fair 'nuff. Possible they could build two out of one, use the old case and input shaft but the later torsion bar. I've never opened the boxes up to actually see what changed inside.
    Jan 2007
    Westmont, New Jersey
    10,373
    Quote Originally Posted by 1985crownvicltd85 View Post
    My suggestion for one with a tired steering box would be to do the alignment with the vehicle running. It may help with centering. You're gonna be slightly adjusting to center the play.
    I did try that too, but it didn't make much of a difference, It was closer but I couldn't get it where I wanted to. I ended up removing the cardone box, and am currently looking to buy a 98-02 steering box.
    Jan 2008
    New Jersey
    2,908
    Gadget- if you find anything out from Redhead let me know, I may be interested in a similar rebuild/mod. maybe with more interested parties it would make them take interest. my box leaks, but still works...for now
    39,252
    I'm not really looking to change whats on my car, mostly was just curious for future reference. You'd have better luck asking them since I don't actually need a steering box.
