Results 1 to 4 of 4
Thread: Idle Air Control Valve Questions
  1. #1
    Sep 2008
    Whitestone, NY
    19,225
    Default Idle Air Control Valve Questions
    Was reading that some cars have a diode in the wiring leading to the IAC and that replacement IAC's may come with the diode already installed internal to the unit and that removing the factory diode from the harness is suggested.
    http://vb.foureyedpride.com/showthre...0593-86-Gt-5-0
    Anyone hear something like this?
  2. #2
    Mar 2010
    Lewisville, TX
    21,650
    First I've heard of it. Don't know why you would remove the diode as it would essentially work as a backup in case the other failed.
  3. #3
    39,359
    never heard of it but I just had a look in my 86 and 91 EVTM. The 86 book shows a diode in parallel with the IAC. The 91 book shows an IAC with an internal diode.
    Its a flyback diode. The only thing it does is conduct when the power is removed from the coil in order to keep it from back-feeding a spike of voltage. No reason you can't have two in parallel. Its not dropping any voltage or anything of that nature. Only real argument I can make for removing it is that if the one in the harness goes bad it will act like a bad IAC and replacing the IAC won't fix the problem. Never honestly heard of anyone having that problem and diodes are like 10 cents so NBD.
  4. #4
    Sep 2008
    Whitestone, NY
    19,225
    Cool. Just wanted to bring this question to this forum and see what feedback comes of it.
