Hood ornament repair
    Last July, my hood ornament wore out - the loop on the bottom for the retaining wire broke through, fortunately overnight in my garage and not on the road. The car didn't have an ornament when I bought it and I have to wonder if the previous one broke in the same manner. These seem harder to find on eBay than others, so maybe it's a common problem.
    Regardless, I decided I'd try to fix this one before shelling out the money for a replacement.
    I drilled a hole in the bottom of the ornament and tapped it for a 4-40 screw. I had to run it just ahead of the remnants of the loop; any further forward and wouldn't fit in the receiver.
Name:	Hood ornament repair 1.jpg
    I wrapped a length of 18 gauge wire once around the screw and threaded it in snugly but no tighter - I doubt the potmetal would handle firm tightening. I wanted to have a washer on the screw, but I couldn't get the wires to quite fit in the receiver properly that way.
Name:	Hood ornament repair 2.jpg
ID:	1305322Click image for larger version
Name:	Hood ornament repair 3.jpg
ID:	1305321Click image for larger version
Name:	Hood ornament repair 4.jpg
    Once I got the wire to sit where I wanted it, it was a simple matter of running into the receiver, slipping the spring over and compressing it, and bending up the wire ends.
Name:	Hood ornament repair 6.jpg
    It does lean slightly forward and the range of motion is reduced, but it's better than not having one on there. I could probably try applying some epoxy to shim it up at the front.
    I have no idea if this will hold up for any length of time, but it was worth a try.
    1985 LTD Crown Victoria
    1996 Dodge Ram 1500 4x4, 360
    Well you are being creative trying to make it work. You might keep your eyes open for a inexpensive replacement just in case.
      Check this out ! I think you can afford this. EB Auction #373115643379Click image for larger version
Name:	Screenshot_2020-07-21 Vintage 1980 - 1989 Chrome Ford LTD Hood Ornament eBay.jpg
