WTB ATC interior temp sensor Motorcraft YH-409
    Looking to buy one of the unobtanium temp sensors for my 85 TC.
    Motorcraft YH-409.
    Thanks.
    I found a used one for you. Ebay #303628051290 I have dealt with the seller before.
    I can't download the auction page for you.
      Here's a direct link: https://www.ebay.com/itm/85-86-87-88...r/303628051290
        Thank you! Just ordered.
          I will suggest you hang onto the old part once removed.
          As best I can tell, the only thing that goes wrong with them is they get plugged up with (potentially gummy/sticky) dust, which means there is hope to potentially restore them with a careful disassembly and cleaning. There are parts inside smaller than the tip of a pen, though, so it requires some care.
          If they truly are unobtainium (as is seeming to be the case), we will need to find a viable strategy to refurb the old ones.
          Current driver: wagon
            Every single one I've replaced has died due to the bimetal spring breaking.
              Ah...that's a more difficult item to replace.
              The several I've gone through have been mechanically intact, but have a slight vacuum leak (not external - the intended vacuum path, just letting too much through) which screws with their accuracy, causing them to prevent the heat staying hot. The best I can come up with for why they do that is dust plugging them up.
                I took one apart just to see how it worked. Not much to it but a needle moving in an orifice and the spring. If the spring isn't broken, best I can guess is the needle jams and hangs open. Possible that flushing it with some gentle solvent would un-jam it. I really don't know, and I don't have a bad but intact one to test. Once you take them apart completely its pretty much impossible to re-assemble. You have to bend the tang on the spring and then there is some tension adjustment that I don't know how to duplicate.
                  There are suppose to be two other manufacturers making this part. Don't know any details other than this:
                  Visteon #330168
                  Omega #2953116
