Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Transmission Noises and Leaks
    Dec 2019
    Fort Irwin, CA
    225
    Default Transmission Noises and Leaks
    I'm experiencing a number of transmission related issues now that the engine's sorted and the car's sat for seven months. Up until now the AOD has run fairly well. There were a couple isolated cases of the car bucking at cruising speed on the way down from Washington, and once before then when the transmission didn't respond to my shift from drive to reverse on the first try. But otherwise it's done its job. The TV cable bushing was missing when I bought the car, but the cable seemed to be wedged in there precariously and I immediately had the brass bushing put on.
    Running the engine tonight and earlier in the week produced a loud sound from near the transmission, somewhere between a buzz and a duck. The first time it was continuous from the point it started, but tonight it began maybe 15 seconds after starting the car and then went away after 30 seconds. I ran through the gears right after starting the car and everything sounded pretty good, but a couple minutes later when I threw it into reverse there was a loud clunk followed by a screech as I shifted back into park.
    There were small leaks that pooled below the transmission. One appears to have come from around the output shaft seal and the other probably came from the pan gasket, but I'm not sure if it could've started above the pan and trickled down. The leaks were definitely transmission fluid, though. There was a third leak at one of the quick disconnects going into the oil cooler, but I took care of that.
    I suspect the fluid is low and hopefully topping it off will resolve some of these noises. The dipstick picture is from 20-30 minutes after running for 4-5 minutes, so more or less cold. I don't understand the difference between the holes and crosshatch on the dipstick, or whether a cold measurement means anything, so I've held off on adding fluid willy nilly. I also don't want to add too much fluid accidentally. I currently have three gallons of Dexron III/Mercon and a replacement filter kit if that seems like the way to go. If so, is this also the time to replace the output shaft seal? Or is this AOD on its way out?
    Here's a video that shows some of the noises: https://www.youtube.com/watch?v=ONP-vwO4Nb4
    6,502
    As I understand it, the lower set of holes are for checking it cold. Should be between the two lower holes.
    You are checking it running, in park, right?
    Fluid color looks decent.
    The buzzing sound is an AOD thing. Some just do it. I had one once that did it a lot but was the best AOD otherwise. I don’t think it’s something to worry about.
    Get the fluid level right, drive it, Hope for the best, and address leaks if it behaves. If something is still grinding inside, there’s not much you can do but pull the trans.
    40,849
    I don't know what the buzz is, but its a "thing". Probably some mix of a slightly sloppy part and slightly high TV pressure making it rattle. My best-shifting AOD also does it.
    not sure what the noise going from reverse to park might be but that doesn't sound like a happy noise. Unless it was bad U joints and the noise was not actually internal to the trans. Still not a happy noise.
    fluid might be slightly low, let it warm up fully and see what you get. Fluid looks OK condition-wise tho. If its not smelly and all the gears work I'd run it till it does something screwed up.
    Above the pan gasket could be from the neutral/reverse switch or from a leaky shaft seal on the shift selector. There is an inner and outer one on that since the TV linkage runs through the middle. Rear is usually rear seal, but if the yoke from the driveshaft has been damaged it will eat the seal. Same if the tailshaft bushing is badly worn. Worth a feel to make sure the surfaces are smooth and the driveshaft doesn't flop around too much when you change the rear seal.
    In the video the speedometer was showing 5 MPH when you put it in park, that would make any transmission grind to a stop.
    Dec 2019
    Fort Irwin, CA
    225
    Yeah, I noticed the speedometer when I was looking at the video. Could've sworn I had my foot on the brakes. So that explains the Reverse to Park noise.
    The buzz has been happening less each time I start the car, but if it's benign then I guess there's no point paying attention to it.
    I added three pints (!) of fluid and after running it through all the gears it looks to be right around the bottom of the crosshatch. The owners manual says to drive it 20 miles before checking, but I'm loathe to drive it too far until I get it smog tested and registered. So hopefully it drives well tonight and going forward. Should I manage to get it legal again I'm leaning toward taking it to a shop for a flush/filter change and maybe the rear seal.
    Dec 2019
    Fort Irwin, CA
    225
    Well here we are a year later and I still haven't addressed the transmission. But the time is definitely approaching.
    There's a pretty significant leak coming out of the rear. Presumably from the output shaft seal, but it drips from the front u-joint. One drip maybe every thirty seconds. I've had the car on jack stands for about a month now and it's still going. The picture below is what's come out in the past two weeks. The fluid, at least, is still red, but I assume it's dark enough that it needs changing.
    Since replacing the transmission mount and u-joints I can't feel any slop between the trans and driveshaft. Is this a good sign that the bushing behind the seal is okay, or do I have to feel it to know?
    I would have already tackled the seal, but the shop that serviced my differential and u-joints really tightened the driveshaft bolts good. Will have to go into the auto craft shop to use a bigger wrench or an air tool.
    20,410
    12mm 12 point wrench and a hammer. Can also double wrench the 12mm12 point:
    40,849
    yeah they're a bit of a bitch to do
    If you're pulling the drive shaft it won't take much to inspect the bushing anyway. There is a special tool to change it though, so unless you have it or are removing the tailshaft it doesn't much matter if its actually bad. There is an O ring on the output shaft of the trans which also is supposed to keep fluid from getting down inside the yoke. If you pull the driveshaft and the splines are full of fluid, you're probably going to need to change that.
    Seems strange to me that the fluid level is high enough to continue to run out the tail end of the trans like that. You can normally pull a driveshaft and nothing comes out, meaning the fluid is below that point. If yours is over-full by a fair bit it will puke fluid.
    Dec 2019
    Fort Irwin, CA
    225
    Thanks, David, I'll give that a try.
    The car isn't level at the moment. The front wheels are off the ground while the rears are just barely touching, so I assume it has more to do with fluid running to the back than the level being too high.
    If the O ring is bad, how do I go about finding a replacement? Is it a special material? I'm sure a rebuild kit would have it, but if I can just buy one part instead of several dozen I don't need, that would be preferable.
    40,849
    its just an O ring, should be able to pull it off and match it somewhere. Standard black nitrile ought to be OK for trans fluid. Green AC O-rings would also work fine.
    tilt would explain the ongoing leak.
    all the CFI are belong to me
    Feb 2014
    Windsor, ON, Canada
    2,104
    Several of mine buzz along similar lines of annoyance as a cicada in a nearby tree. Sort of like your buzz, but it ramps up and does not waver once it reaches its full intensity, before it eventually trails off and is gone until its next appearance. It seems to just be what they do. After driving, if I shift into park, it will buzz for a minute or so, then stop. I can shut it up immediately by moving the lever to any other position, then when I put it in park again, it may or may not begin buzzing again. On the cars where I have TV set on the high side (to shift in a manner I consider more desirable), two other conditions can get the buzz as well: using manual 1, or accelerating in D/OD gradually enough over a long distance that I'm in second gear for a long time.
    All of the cars I've put any sort of mileage on have had their trans fluid changed with a store brand (Shell-manufactured) DexIII/Mercon equivalent. It is not marketed as synthetic. Not sure if the fluid maybe plays a role.
    I would guess, and I think this comes from past input of others, that the buzzing is a vibrating check ball in the valve body being rapidfire seated-unseated due to something about how the fluid is being routed in those moments.
    A sound that I get which others seem to not talk about is a very high pitch squeal noise (think noisy CRT TV) at the top end of gears right before a shift. I've now had enough of my cars do it for long enough that I'm convinced it is also just a normal thing. I am very sensitive to noises that many people around me seem totally unable to hear, so I'm sure that's part of it.
    Current driver: 85 Ranger
    Panthers, Parked: 83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 86 GM | 88 TC | 91 GM POTM 12/2017
    Not Panthers, Parked: Ranger trailer | 05 Focus | 04 Focus
    RIP: 97 CV | 83 TC
    Junkyards
    40,849
    AOD's have fairly straight-cut gears, a whine in 1 and 2 especially is common. The AODE and 4R70w do it too.
    Feb 2014
    Windsor, ON, Canada
    2,104
    Assuming that is with respect to my remarks and not an in-general: Not that sound. I know that sound. This is a hydraulic sound...maybe a high pressure leak past a valve or something.
    I've come to accept it as just being normal, or at least normal with age. Anyone older than me can't seem to hear it at all.
    RIP: 97 CV | 83 TC
    Junkyards
    Jan 2008
    New Jersey
    3,211
    According to the Baughman shift kits I have used- the buzzing sound can be fixed by replacing the TV spring with an updated (possibly stiffer, it was hard to tell) spring that comes with the kit. I'm not sure if you can buy the spring separately, but if it really bothers you, you could replace it, or do a mild shift kit since you're already in there...
    If you take the tailshaft housing off it's not too hard to replace the bushing. I use a sawzall blade to carefully cut through the old one, at which point it'll basically fall out, and use a piece of wood and hammer to gently hammer the new one in.
    Driveshaft bolts-sometimes they use locktite and heating them a bit first helps break the bond
    Dec 2019
    Fort Irwin, CA
    225
    Well I pulled the driveshaft today. The double wrench trick worked like a charm. I frequently find myself just not giving things enough muscle, or worrying too much about breaking things. Maybe that's from growing up working on computers. Anyway, this has been a great opportunity to clean the driveshaft and tunnel of all the caked on oil that I assume was deposited from the intake manifold when its gaskets failed. Not very fun removing sludge that's above you, but the results are satisfying.
    Now that it's off, I've found a couple things:
    One, the output shaft splines are full of fluid, which I understand means an o-ring has gone bad. I don't see any o-ring, though. Does it require removing the tailshaft housing to replace?
    Two, the bushing and driveshaft look to be okay. I didn't notice any marring on the driveshaft, so I'm probably going to leave the bushing be.
    Three, fluid seems to have passed through the middle of the driveshaft to drip from the u-joint. It looks like there's some sort of black seal in there. Is this something that needs to be serviced or will the output shaft o-ring keep fluid from getting there?
    Four, the output shaft seal Amazon told me would fit (7692S) doesn't. It looks to be almost 2 1/2" diameter, while the old seal is closer to 2 3/8". Does anyone have a part number for a seal that will fit?
    40,849
    O-ring is under the tailshaft housing. Once its off you'll find it just forward of where the splines on the output shaft are. Thats whats meant to keep fluid out of the splines.
    master parts manual has E2DZ-7052-A listed for the output shaft seal. Rockauto shows SKF 14978 as a cross with an OD of 2.376"
    Dec 2019
    Fort Irwin, CA
    225
    Thanks, Gadget. I pulled up a Precision Transmission video and saw the o-ring, too. Looks like I'll be pulling the tailshaft housing. Hopefully I can get it out without needing to mess with the cross member.
    Is there any harm in painting the driveshaft? It didn't look like there was any coating from the factory, but perhaps it's worn off.
    22,607
    Paint that's not applied evenly will unbalance the driveshaft. That's the only real danger.
    40,849
    The trans mount will need to come out but I think you can probably get the housing out with the crossmember still in place so long as you support the trans . The tailshaft is basically an ice cream cone, so once you unbolt it and slide it back slightly you can tilt it considerably for clearance.
    might want to change the O ring on the VSS while you're at it just because. You'll also want a new tailshaft gasket.
    Dec 2019
    Fort Irwin, CA
    225
    I've already ordered a tailshaft gasket, (hopefully) correct output shaft seal, and a box of nitrile o-rings. If I have one the right size I'll be sure to swap out the one on the speed sensor. I also long ago got an o-ring for the dipstick, as I thought a drip coming off the pan might've been coming from there. Now seems like the moment to do that one, too.
    As far as the driveshaft goes, I've heard that paint, dirt, and rust can all throw the balance off. There's surface rust on maybe two thirds of it right now. I just wonder how fussy the balance really is, because two coats of spray paint doesn't seem like all that much. But if they usually live uncoated then I guess they're not as susceptible to corrosion as I thought.
