Results 1 to 19 of 19
Thread: EEC-IV speed limiter
    Default EEC-IV speed limiter
    Is there anyway to remove the speed limiter on the EEC-IV? I have a 1990 Grand Marquis
    I know it can be chipped, if that's the only route does anyone know of any Speed Density EEC-IV tuners on long island/NYC area?
    19,392
    The only limiter is the stock engine as far as I know.
    21,792
    I don't think the ECM used a speed limiter until 92 with the electronically controlled transmissions. That was set at about 110mph IIRC. I think the boxes are RPM limited due to the 3500-4000 rpm limit of the engine and that's only really possible in 3rd gear as 4th will slow you down at that point because it doesn't really have the power to push the car faster.
    Ah ok, I'm having 4.10s put into it but I haven't changed the speedo gear and I was just worried about it topping out going 80 lol
    39,640
    its engine RPM limited at like 6200. The stock parts won't let it spin that fast anyway unless you just mat the pedal in neutral.
    5,843
    It’s kind of sad we don’t have a speed limiter because we can’t go fast enough to need one...
    19,392
    Tall gear ratio...like a 2.73 gives the engine the opportunity to reach some high speeds. Just need some long stretches of road to get there.
    Sep 2014
    Warren, MI
    6,044
    You don't need to, these are cruise cars. I've had my Town Car almost seven years now and never once felt the urge to push it past 85 or 90. I've got my Firebird for that or even my truck.
    39,640
    In theory they can go fast with tall gears, in reality between the lack of aerodynamics and the 150 hp engine its just not going to. I've had mine going way too fast before, it makes unsavory noises. Doesn't get unstable tho.
    Sep 2014
    Warren, MI
    6,044
    They are among the quietest and best riding cars at and below 60mph.
    Jan 2007
    Westmont, New Jersey
    10,381
    There is no speed limiter. They couldn't go that fast anyway.
    39,640
    They're OK even in the 70-75 range but box Towncars over 100 whistle loudly from the mirrors, and over about 120 the grille on the 85-87 at least will push in and go crooked. Its still a surprisingly controlled drive, but you can tell it simply was not intended to go that fast.
    Also you stand a high chance of your heater core failing with stock engine pulleys, especially if you don't have a restrictor in the line. The accessory drive was engineered for tall gears in OD at a national highway speed of 55. I've been in two of these cars that had a heater core explode when the rpm got over about 4000. One was my own car somewhere well over 100 mph, one was Natehawk's car when the 351 went in. His popped just before the first 1-2 shift on paved road. Having the windshield suddenly become a sheet of solid fog when you're going fast is not my idea of a good time.
    Nov 2014
    Evans, GA
    1,650
    I'll say a 3.27 RAR and a single pipe LoPo can manage 101 MPH, but make sure your valvetrain isn't tired, unless you want to see if your exhaust valves are any good. It also takes a minute to get there.
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
    Sep 2014
    Warren, MI
    6,044
    Well yah, the original crowd that they were designed for and who purchased them never went that fast. Would have been a waste of resources to make high speed feasible in one. Doubt the barges of the 70's were any better. They do ride OK at 70 - 80, but hot damn do they ride like velvet at 60.
    LoL I remember reading about that story of yours regarding the speedlimiter, aka heater core. My inlet has a restrictor yet my heater core has failed anyway. I just can't get myself to tear open the dash nor am I comfortable farming it out for fear the car will never be as tight & quiet as it currently is.
    If you think these things take a minute to get up to speed, drive a 2.3 powered Ranger from the early to mid 90's. They barely do 90 mph with the throttle matted to the floor.
    39,640
    Its not the end of the world pulling the dash. I've done mine twice. The first core I put in was bad out of the box. Only real trick is to not hurry so nothing breaks.
    Apr 2015
    Southern Commiefornia
    2,350
    I have a new heater core that i never put in the first '90. Should i have that done when the new engine goes in? Not sure the age of the one in there.
    39,640
    replace it when it fails. It comes out from inside the car, so engine in vs engine out honestly doesn't make any difference. if it doesn't fog the windshield and stink like coolant though, let it ride.
    Iíve replaced two, one in my old 85 cv and my current 87 mgm. Neither was that bad and can be done with just one side of the dash unbolted. Getting everything lined back up can be a pain since doing it that way you have to kind of angle the front up. If thereís any coolant left in the heater core it will spill. The po of my 87 was nice enough to cut out the carpet all the way to the seat so there was nothing for the coolant to soak into lol.
    Sep 2014
    Warren, MI
    6,044
    Everyone who "can" says that sort of stuff. There are a lot of things I'll do and many more I won't. That's just something I don't feel like doing unless I had assistance from someone who has. I hardly drive the thing nowadays anyway, it's probably time to sell it.
