Results 1 to 5 of 5
Thread: Where can I find door moudling clips for 90-94 TC?
  1. #1
    n00b Auxient's Avatar
    Sep 2018
    Elko, NV
    8
    Default Where can I find door moudling clips for 90-94 TC?
    I just picked up a 93 Lincoln Town Car last week and yesterday some jackass backed into my passenger front door and ran. He hit it right in the door trim and damaged it and when I went to open the door, it caught in the fender and broke the clips for the door trim. It broke the end clips with the studs and then all of the clips that go in the door itself. The clips on the moulding (aside from the end ones) are intact. I plan to get the dent out and use some heat to bend the moulding back but I cannot find where to get these clips and it is very frustrating. I have attached some photos of the clips in question. Thank you.
    These are the clips that go on the door itself, these are primarily what I am looking for.
    And then I need these special clips with studs that go at both ends of the trim as seen here. You can see the ends are still stuck in the door in the above photo.
    And here is a good picture of the car, just because.
  2. #2
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,557
    I just did a search and found a company that might have what you need: https://www.nationalautobody.com/cat...=281_1419_2339
    '79 Continental Town Car (The steering gear will be replaced very soon.)
    '90 Crown Victoria LTD
    '94 Crown Victoria
  3. #3
    Sep 2018
    Elko, NV
    8
    Quote Originally Posted by 79lincolnlover View Post
    Thank you but they don't have the clips. They seem to have the chrome strips and stuff but no clips.
  4. #4
    Donating Member
    Oct 2011
    USA
    241
    Not sure if my 93 MGM has the same clips, but I’ll check and see. If they are the same you can have them since I am junking the car
  5. #5
    39,916
    https://www.clipsandfasteners.com/ has a lot of that stuff, not sure if it has the specific ones you need though.
