Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 93
Thread: 2001 crown vic
  1. #61
    Mar 2010
    Lewisville, TX
    22,156
    Quote Originally Posted by 82EmilioPucci View Post
    Would a mustang upper plenum do much at all?
    Nope. Exactly the same part as of 2001 to the 98-04 mustang.
  2. #62
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    139
    Ok, next question to fall, lol, what intake is best intake, are the heads being a 2v to restrictive for any to help much?
  3. #63
    Mar 2010
    Lewisville, TX
    22,156
    If no boost... stock 01+ intake is best because already there. Get the larger intake elbow and throttle body from ADTR.net along with maybe their zip tube and have a nice day.
    If boost... stock is good to something like 15 PSI? Maybe only 10? If doing totally built boost monster using a dart block and all kinds of forged goodies... all aluminum intake is the way.
  4. #64
    Jun 2019
    Albia, Iowa
    139
    New question, I've been doing the console swap for a while, its real cold here, and I've got the shift assembly in and the cable rerouted, but it is pretty tight up against the exhaust. It appears to be in the same spot as dRock96Marquis guide and he just says route carefully and not against the exhaust, I guess my question is will it be fine to rap it in heat shielding along with the manifold its touching
  5. #65
    Jun 2019
    Albia, Iowa
    139
    Heres pictures
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	55763   Click image for larger version.
  6. #66
    Jun 2019
    Albia, Iowa
    139
    There is a bracket neat there i am going to bend and take one of the white clips to hold it off the exhaust, I will also be putting heat shielding there 2
  7. #67
    I post a lot...
    Dec 2011
    Yonkers NY
    4,282
    that is too close for sure
  8. #68
    Jun 2019
    Albia, Iowa
    139
    Mmmm, that second picture is how I held the cable off of the exhaust, I didn't see any pictures of how other did it, there is a bracket there that held the cable before, i folded it over on its self and metal zip tied the cable in place
ID:	55815   Click image for larger version.
  9. #69
    Jun 2019
    Albia, Iowa
    139
    So I went out a bought a 75mm mustang upper plenum and a 5.4 throttle body, and was wondering if a slight whistle when ya blip the throttle is normal, it doesn't like increase, just from from maybe 1000-1200 and stops as revs continue, revs normally, the air tube and air box are stock, its pretty cool, but was wondering if it's bad
  10. #70
    Mar 2010
    Lewisville, TX
    22,156
    May indicate a bad or misaligned seal/gasket. Maybe a tab hanging inside the air path. Usually air induction (getting sucked into the intake) sounds more like a woosh/hiss than a whistle.
  11. #71
    Jun 2019
    Albia, Iowa
    139
    I think it was the map, I didn't have a connection on it plugged in all the way
  12. #72
    Jun 2019
    Albia, Iowa
    139
ID:	55850 mmm? What do ya think,
    Edit: I have no idea why it's upside down
  13. #73
    Jun 2019
    Albia, Iowa
    139
    New problem lol, first would the tuner, big throttle body, and 75mm upper plenum make a big difference in the fuel trims, they are at 14% on the long term, second my brake and abs light come on randomly, the longest it stayed on was 5mins and today on the highway they blinked on then off. Third my compass on my rear view mirror will work fine, then show random pixels, or today it was OC. Thanks for any leads
  14. #74
    Jun 2019
    Albia, Iowa
    139
    Done some reading the abs and brake light, with no com, intermediatly mean she going bad, on a good note, you can just replace the computer bit and no brake fuild is lost
  15. #75
    Nov 2012
    Shelby Township, MI
    3,433
    Orientation data and actual orientation sometimes don't agree when it comes to image files. Some applications use one method to display the image while others don't, that's basically why the picture looks fine on whatever device then wrong after posting. The application on the device uses one method while the forum uses another method.
    Rotated:
    That blue looks a bit brighter. The rest of the interior would look good in that shade of blue.
    I don't know enough to answer any of the other questions.
    ~ 1997 GMC Yukon - wannabe winter DD - returning sometime in the 2020s, I finally have an engine
    Gone but not forgotten:
  16. #76
    Check your fuel pressure at idle and under load, the pump may be getting weak.
    Also you could have low brake fluid, a sticking caliper or a dirty/broken abs ring. Check the fluid level first. Does it pull when off the brakes? Does it pull when you hit the brakes?
  17. #77
    Jun 2019
    Albia, Iowa
    139
    Quote Originally Posted by 87GrandMarq View Post
    Ya, it does occasionally drop fuel pressure, causing a long crank, does it maybe once a week, only on start up, seems fine but never checked it after all the mods, have a pump, but havent do it yet lol, the fluid is good, the traction control button still works, so I think the sensors are fine, does have a new one, the car brakes straight, maybe a little right, but drive straight with no pulls, but I have no communication with it occasionally and no codes when I do, I think
  18. #78
    Jun 2019
    Albia, Iowa
    139
    This is a little off topic but, I'm going to look at a 'parts car' this weekend and it's a 98 mgm Texas car, but has an overheating issue, it looks like it has a new
    water pump, and I looked at the service history and it has a new radiator, New upper hose and the upgraded intake with the metal insert, wondering if anybody has any ideas
  19. #79
    Jun 2019
    Albia, Iowa
    139
  20. #80
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,726
    Water in the oil? Do a coolant pressure test. Do a combustion leak test. When did the owner have this problem? Before or after the new intake installation ?
