Page 1 of 5 123 ... LastLast
Results 1 to 20 of 92
Thread: 2001 crown vic
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    138
    Default 2001 crown vic
    My most recent purchase, 2001 cv, old dot car, 93,000 miles.Click image for larger version.
ID:	54976 has an issue with a long crank after about 2 hours (shorted time I tried) where it won't start on first crank, the day before it got ran low on gas(not by me) and the first 2 starts that day didn't do the long crank, it does seem down on power( tho I wasn't get to into it) is there a way to test the regulator?
    Jun 2019
    Albia, Iowa
    138
    Think I found some doors on a 2000 mgm tho the junk yard said they wouldn't fit, anyone know whats different on them or waht years are interchangeable? Thanks
    6,189
    The check valve in the fuel pump maybe picked up some crud, causing the long crank times. I think I’d just drive it if you can get it start eventually, maybe some fuel system cleaner and Hope it clears out. Change the fuel filter after that tank is gone.
    On the doors, the Merc doors should bolt on. The trim is different. The mercs usually got a giant hunk of plastic trim. I think the doors are the same minus any holes for mounting the trim. A body shop can make them work.
    Oct 2008
    St. Louis, MO
    681
    Search car-part.com for the doors. I'd bet you can find a set without having to deal with the extra holes from the Merc doors. Might even be able to find the same color if you're lucky.
    40,138
    ever checked the fuel filter? Might have sucked up some trash and plugged the filter.
    Jun 2019
    Albia, Iowa
    138
    Quote Originally Posted by FordMan77 View Post
    Thats the first place I looked lol, closest the same color was 400 miles, the yard i was looking at was about 50 with the same color door, but a mgm
    Jun 2019
    Albia, Iowa
    138
    I do have a filter, I'm going to put on soon, but its weird the cold start this morning was quick, but when I started it about 12:30 I had to cycle the key
    Jun 2019
    Albia, Iowa
    138
    Mine has the front moldings, and the mgm doesn't seem to have any extra chrome or anything
    Jun 2019
    Albia, Iowa
    138
    Something interesting, on carpart I put in 2000 instead of 2001 and got thisClick image for larger version.
ID:	54991 the 06/01/00 get the same results as the 2001 search, the 5/31/00 gets different ones
    Jun 2019
    Albia, Iowa
    138
    Unicorn located
    Jun 2019
    Albia, Iowa
    138
    The long crank problem self healed ��, a new question though, I just got done installing 3.55s in the vic and the speedo is off by about 20 mph, and didn't know if anyone had any idea what speedo gear I need, thanks, ps the car had 2.73s
    40,138
    With the later cars I'm pretty sure you fix it with a tuner, not the speedo gear. It uses engine rpm and the VSS to determine shift points and if the PCM doesn't know what gears are in there it gets stupid about things.
    Nov 2014
    Evans, GA
    1,754
    2001 uses a VSS gear; no tuner required.
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
    Didn’t Ford stop using the vss in the 4r in 01? Even so, I’d recommend a tuner instead of a gear swap so it can correct for the new gears and fix the shift points.
    Jun 2019
    Albia, Iowa
    138
    Thanks for the info and website, just ordered my 21 tooth gear, I seen some stuff about 8 tooth to 23 tooth will wear fast, will the 21?
    Jun 2019
    Albia, Iowa
    138
    They stopped using vss in 03 for cv and mgm, 98 in townys I think
    Jun 2019
    Albia, Iowa
    138
    Would a tuner be a lot better?/ are they super expensive?
    My bad yes you are correct it is 03, I don’t want to spread misinformation.
    A tuner will be better because you can tune for the new gears instead of swapping speedo gears and you can tune the new shift points. But it is more expensive as you’ll have to buy the tuner and a tune.
    Jun 2019
    Albia, Iowa
    138
    Ya I just found out the shift points lol, ready 40 and is in od at when my phone says 30
