2001 crown vic
Originally posted by 82EmilioPucci View PostWhat do you guys think, I'm not a fan of the column or dash mounted ones.[ATTACH=CONFIG]55178[/ATTACH]
Originally posted by 87GrandMarq View PostI’d swap to a 99-04 mustang cluster personally. I think it looks better but that’s me.
Sent from my iPhone using Tapatalk~David~
https://www.crownvic.net/ubbthreads/...Number=1330179
It was actually a 94-98 cluster. But yeah it’ll need to be repinned to work. Looks good though.
There's no tach output from the PCM from 99-2004, so tach adapter would still be needed to make that cluster work.
Originally posted by 87GrandMarq View Posthttps://www.crownvic.net/ubbthreads/...Number=1330179
https://www.ebay.com/itm/96-14-UNMAR....c100889.m5204
Will this tuner work to reprogram the pcm to know the car has new gears, like can I just go in and change it, I'm knew to not stock sort of thing. And you guys were 100% right the gear helped, the speedo is off by about 5mph at 60 and it shifts a little early still.Last edited by 82EmilioPucci; 11-18-2020, 11:57 PM.
Yes. Keep the original speedo gear on hand in case setting the gear change makes the speedo read slow. I forget what year the PCM started feeding the speedo instead of the speedo reading the VSS directly.
As long as it's the same SCT model number and unlocks are available, it should work. Might even get a little power bump from it as it may have a canned tune that's a little more aggressive than stock.
The tuner was worth it, shift harder and the shifts are later, I did the strategy tune after the custom, does it increase the red line?, before the tuner i saw 5 at most and after I saw 5500 and let off, I didn't change it, all I did was rar and speed limiter. I guess my question is stock will they handle that?
