Results 1 to 20 of 20
Thread: Recommendations for Stall Speed on Torque Converter
    Nov 2014
    Evans, GA
    1,727
    Default Recommendations for Stall Speed on Torque Converter
    Essentially as the title states, what’s roughly the best estimate for a regularly driven car with the HO setup? I’ve seen numbers as high as 3000, which sounds like it’ll hurt economy even more than normal.
    I know the factory AOD converter stalls around 1600-1800, and makes the car feel numb, but I expected that. Since mine has to come out, now is a good time to try and rectify that.
    Does a 2200-2500 stall converter sound adequate in a car our weight, or do I need to shoot a touch higher? I’d like to keep a lock up converter for fuel economy, but I don’t want to also wind up in a situation where the shift from 2-3 breaks the direct input shaft under WOT conditions.
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
    Jan 2008
    New Jersey
    3,070
    The HO cam gets started around 2500rpm, so i think you are right in the ballpark with a 2200-2500 stall converter. Since it's not just a race car, i personally wouldn't go above that. Unless you got stuck with the short straw, your input shaft should be just fine with a stock HO motor.
    40,017
    2500 is about right for an HO cam. No point in making it much higher, you'd just be wasting power.
    Something that I found really made a difference to extend the low rpm torque was a ported lower intake. I used a Holley SystemMax 1 but its basically the same as a ported stock lower. Uses the stock upper intake. It evens out the airflow into the cylinders and made a much bigger difference on an otherwise dead stock HO than I'd have ever believed. You may get similar results out of a stock Explorer intake, I don't know.
    Nov 2014
    Evans, GA
    1,727
    Thanks y'all for confirming on that.
    Now I see there's plenty of options out there. Obviously I'm not gonna shoot for some eBay special to figure out how quick it doesn't work.
    Any thoughts on this? https://www.transdepot.net/tdaod2500lu
    Jan 2008
    New Jersey
    3,070
    That was one i was looking at too. The transdepo in general doesnt have good reviews on its transmissions...however IDK how that compares to the quality of its parts. It is nice that it is brazed (i see a lot of B&M's are not)
    Jan 2008
    New Jersey
    3,070
    Also, keep in mind that the HO motor doesn’t make a ton of power, so you will probably be at the lower end of the stall for that
    Nov 2014
    Evans, GA
    1,727
    Yeah, it took some hunting to get some info on the people themselves, but couldn’t find much on their converters.
    Someone on the CVN Discord pointed me towards Roadrunner Converters. I picked up their 2200-2600 Stall Converter instead. Seems they have pretty favorable reviews all around. They also have higher stall 10” models for AOD, but I figure I’ll be okay with one that’s getting onto the power band, even if it’s at the threshold.
    40,017
    just make sure you match it with your input shaft config. Need the 2 shaft setup unless the trans has been modified. If you're going to a non-lockup type you'll want more trans cooler too. That page doesn't give quite enough info to know exactly what it is, but if you talk to the guys that sell it they ought to know what you're talking about. For a street / DD type car I'd probably retain the lockup.
    Jan 2008
    New Jersey
    3,070
    The Roadrunner is certainly affordable- but almost no info included with it. If you are able to find anything more about it, it would certainly help
    Nov 2014
    Evans, GA
    1,727
    I guess I'll know whenever it shows up. I'll look and see if it has the three splined sections inside compared to the non-locker two spline ones.
    Either I have made a timely (and costly) ordering mistake, or the correct option I'm needing.
    Jan 2008
    New Jersey
    3,070
    Yeah if it comes with all the info on a paper, and you can post it up, i'd greatly appreciate it! I'm currently leaning towards this converter: http://www.edgeracingconverters.com/...d-aod-p-1.html
    Nov 2014
    Evans, GA
    1,727
    Well the converter arrived today. Outside of arriving with my invoice and a sticker, there was no specification paperwork.
    I count three splined sections, so I assume it to be a lockup unit:
    40,017
    Not neccesarily. Its designed to work with the stock shaft, but it could have both sets of splines connected to the turbine rather than the outer to the turbine and the inner to the shell like stock. If you poke the inner shaft in there it should be easy enough to figure it out. The turbine you would be able to rotate without turning the whole shell, if its connected to the shell you won't be able to do that.
    Nov 2014
    Evans, GA
    1,727
    I really couldn't "turn" anything as it sits, however I could prod the large outer splined area, and it moved a little, same with the middle section. The small splined area wouldn't move and seemed to be separate from the middle section.
    40,017
    sounds like a lockup then.
    Nov 2014
    Evans, GA
    1,727
    I figured it would be worthwhile to give this thread a bump with just some collected driving data on the Roadrunner converter.
    So the unit is indeed a lockup unit that will fit on a stock input shaft. Particularly nice if you want the extra stall speed in 1st and 2nd, but would like to retain lockup for economy in 3rd and 4th. Mine performs within the advertised stall speed (2200-2600) and will flash stall around 2500 RPM. I also did a brake stall test, loaded it up to 2500 RPM, and let it rip while keeping the selector in 1st. Engine speed jumped to about 3000 RPM, and stayed there during wheelspin until it caught, then it continued to rev on up before I moved the selector into Drive.
    I could never light up the tires before, but now it'll do a mean peg-leg burnout.
    For typical, in-town driving, its been fine. It does most of its shifting around 1800-2000 RPM in 1st and 2nd, which is great starting from a stand. Only when I first got it from the shop was I finding it a little "un-fun" to get started since it would wind up a fair bit (2200-2300) before it really started going. Now that its been driven on a few hundred miles, it starts off fine with light or heavy throttle.
    Hopefully it keeps working well. So far, I have no standing complaints with this one, even despite the limited information on their website.
    Donating Member
    Oct 2011
    USA
    252
    That is great news! Glad you are enjoying it
    Jan 2008
    New Jersey
    3,070
    Good information! Odd that it had to "break in" to start working how you'd expect. I wonder what changed? Perhaps there was an air pocket trapped in it that got burped out
    Nov 2014
    Evans, GA
    1,727
    No idea. Initially it sounded like someone unfamiliar driving manual riding the hell out of a clutch. I already expected more RPM needed to get started, but it really needed some. Originally I was starting at like 40-50% throttle to actually get going with traffic, but now I can drive it normally as I have before without needing to call for more accelerator.
    Having no experience with any other brands or driving anything else with a higher-than-stock-stall torque converter, I don't have much to compare it to for a new out of the box one. I had no idea if there was a break-in period on a converter.
    Donating Member
    Oct 2011
    USA
    252
    It just takes some getting used to
