Lower Intake Manifold
    When the lower intake gasket fails on the lopo engines; where does the oil come from? The only thing I can think of is the pcv valve port. Other than that, wouldn't it just be coolant and a vacuum leak with a bad intake gasket? What am I missing? Just curious as both the '86 CV and the '91 Ranger had bad lower intake gaskets that puked oil down the back of the engine.
    oil leaks onto the bellhousing and down the timing cover usually. the seals in the middle of the intake usually go first.
      Here are some pictures of the condition:
      The leak is probably coming from below the coolant passages where the manifold meets the top of the block. I think the original gaskets there were cork, and when I removed mine they came out in several crumbly pieces.
        The answers above both answer the question, but to add a little context: the valley of a SBF contains oil that is splashing around from the operation of the lifters/pushrods. This is why the front and rear seals/gaskets have oil behind them to begin with.
        In my non-exhaustive experience I've found the coolant leaks to be a bigger problem (in terms of volume and how often it needs to be compensated for). Coolant into the adjacent intake passage, or coolant escaping to the outside world. None of mine have put coolant into the oil yet but it is also possible, and would make the engine need a rebuild very quickly if it happened.
        Current driver: wagon
          Scott, Lutrova, and kishy; thanks for the clarification. Totally forgot about the actual lifter valley 1st gen sbf have. When I was thinking about this over the weekend, I was thinking along the lines of a 4.6 mod motor valley. What little time I spend on my MGM, seems to be too much time; as it is twisting my mind.
            Those end wall gaskets are like 1/4" or so thick, so when the cork shrinks it makes a pretty good gap to leak from. The rubber seals work a lot better. Most pushrod V engines have the same basic design and tendency to puke oil from that spot.
              I'll add that if your PCV mesh filter becomes clogged, the cork gaskets will be the first ones to get blown out. Mine also came apart in crispy chunks when I redid the top end gaskets.
              My car also had an issue with the original oil pan gasket. The mesh was completely clogged causing pressure that blew out a corner of the oil pan gasket.
              —John
              1985 Ford F-150 XLT Lariat
                That's what killed the lopo in the '86 CV. Clogged pcv screen that I couldn't remove; which in turn must have put pressure in the intake and valve covers. Put a lot of oil in the throttle body and coated the underside of the car all the way back to the rear axle. Kinda defeated the purpose of me painting that rear after the rebuild.
