Results 1 to 6 of 6
Thread: Box CV fuel sender
    Default Box CV fuel sender
    https://www.ebay.com/itm/Herko-Fuel-...gAAOSwqG5dVwhr
    This appears to fix my 87 CV 5.0, but fitment says NO. Anyone got experience with this thing? Thanks guys.
    19,883
    Here are some thing to visually compare.
    http://www.grandmarq.net/vb/showthre...l=1#post644164
    Unless there was a resistance difference between the fords Vs the merc and townies Id say it would work.
    Mine looks exactly like your pic and the pic from Herko. I may pull the trigger. Its only one part of my fuel gauge saga though.LOL
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,945
    I have purchased this item previously. It is correct for an EFI box sedan, prior to 90.
    Wagon fitment is unclear (should work maybe with some mild bending). Carb car fitment is a solid no. 90+ fitment is a solid no.
    83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger +trlr | 86 GM | 91 GM POTM 12/2017 | Junkyards
    Gone: 97 CV | 83 TC
    May 2014
    105
    The Herko is working so far, 20 miles, in my 87 mgm. Mechanic #3 said it wouldn't and preferred the reinstallation of the rusted out original. "You don't need no stinkin' fuel gauge." Mechanic #4 got the fuel system working and the car running by jumping the relay, but then replaced the fried computer. It seems one circuit near there is a ground, and 12 volts accidentally applied kills the computer. But was it testing by mechanic #2,3, or 4?
    1987 Grand Marquis LS two door, trying to get to the 60,000 mile mark.
    Quote Originally Posted by jim View Post
    Thank you for the update.
    1987 CV LX 5.0
