Results 1 to 5 of 5
Thread: 88 lincoln towncar door wiring
    Default 88 lincoln towncar door wiring
    Ok I have a 88 tc I had to switch doors and the only door I could find was one from a 86 tc. Anyway I'm having trouble wiring it up correctly wondering if anyone could help with a wiring diagram or something anything helps
    22,060
    If you still have the old one... probably best to switch out all of the electricals.
    Unfortunately I dont
    22,060
    In that case, you'll have to wait for someone that has the EVTMs or find yourself some online for both years.
    40,010
    what do you mean exactly? How did you remove the door and its wiring? When I did mine, I fished every inch of wiring out of the door and laid it in the car, then after hanging the door the wiring all got fished back in. It was extremely annoying but no wires were cut. Did that five times, replaced all 4 doors then someone backed into the car and one had to be replaced again.
    I hope you didn't cut the wiring otherwise you are going to have a huge mess on your hands.
