I have power side mirrors from an 86 vic, and id like to swap them onto my 85, I was wondering if anyone has a wiring diagram, so i can wire them in correctly, thanks.
Power side mirrors
Should be the same connector. I don't think that changed until the 90s.
I have done this trick and it works for a while. After time the mirrors seem to stick.
Have someone on the passenger side help you. Hold the mirror glass, then as you use the mirror control l, put a little pressure on the mirror glass to guide it through the range of motion. It is worth trying first vs replacing mirrors.
I ended up trying again after work. I removed the mirror and then bench tested again, there are two spots where the mirror sits in and one turns it side to side, and the other up and down. both work without the mirror installed, so I then lubed the "hinge" on the back of the mirror and worked it up and down, I then placed it back in and tried again, now it works in all directions. (sorry I dont have pictures)
