Results 1 to 13 of 13
Thread: Crimping Tool
    Nov 2006
    Dirty Jersey Yo!
    8,239
    Post Crimping Tool
    So I just tried out the Wirefy crimping tool I bought a month ago. Up until this point; I was crimping with a set of channel locks. Then I had a crimp come apart and realized I needed to upgrade. Should have gotten this tool long ago. It has me thinking of building my own harness connectors to make wiring easier and a bit more functional. Just thought I'd share my experience/blunder.
    40,031
    channel locks are not crimp tools. Proper ones actually make connections that don't fall apart, shit ones make you hate crimp connectors. Shitty crimp connectors also don't work well no matter what kind of tool you use.
    Dec 2011
    Yonkers NY
    4,266
    I never saw one with a square crimp like that.
    Nov 2006
    Dirty Jersey Yo!
    8,239
    Yah, that is one of the dies that came with the tool. Even when I was younger and had stronger hands; I couldn’t make a crimp like that. I’ve been pulling on this test crimp for a few hours; even had my Dad pull on it (still has stronger hands); it’s very tight. In the not-so-distant future; I will get a Deutsch connector kit and start practicing making those.
    Where's the tool.... man! lol
    1987 CV LX 5.0
    Member tbear853's Avatar
    Jan 2021
    Virginia but I started life in Texas
    32
    I strip the wire end 2x as needed, fold wire upon itself usually once, remove plastic color with a twist, insert wire, lightly crimp to not break or cut strands, solder with Kester rosin core using Weller Jr. gun, then usually add a wrap of Super 33 tape, then add shrink tube segment, heat as needed, done.
    40,031
    I'd actually like to find terminals like the OE ones that crimp into an M shape. I've done that with the special terminals but they must exist for common 1/4" spade connectors and splices and the like. No insulation on those, have to use heat shrink, but they are a much smaller end result and seem to be pretty mechanically robust.
    Donating Member
    Oct 2011
    USA
    252
    I used to buy OEM style terminals from rjminjection tech.com but I think they are no longer in business. You can find stuff on eBay.
    I think I still have a bunch lying around somewhere.
    There is a special crimper for those that has the M shape. It will also crimp the factory weather seals.
    https://img2.tongtool.com/u/64679d9a...9ad6f5pvmK.jpg
    For regular style crimps I use the blue point crimper, works great zero problems
    https://i.pinimg.com/736x/39/c9/f0/3...a2b838e98b.jpg
    Attached Thumbnails Attached Thumbnails 64679d9a4867d36f4bc7b6be77ad9ad6f5pvmK.jpg
    Nov 2006
    Dirty Jersey Yo!
    8,239
    Quote Originally Posted by mcb82gt View Post
    This one...... https://wirefyshop.com/
    Dec 2011
    Yonkers NY
    4,266
    I have been using good crimpers similar to the blue point units for years and they get them properly tight but not always pretty.
    40,031
    clipsandfasteners has the OE terminals. I have the crimp tool for them. I know they make "common" crimp terminals that use that OEM style crimp method though. The BMW sensors in the Continental have them. All common 1/4" spade but the crimp to the harness is the M crimp.
    My regular crimp tool is like that Blue Point but they came from Harbor Freight. Still work well, way better than the crappy crimpers built into most wire strippers.
    Birdsboro PA.
    17,640
    my good crimpers are mia. might have to look into this set.
    Donating Member
    Oct 2011
    USA
    252
    Definitely. I can’t stand those style wire strippers/crimpers.
    For wire strippers I have these 2:
    https://i.ytimg.com/vi/tmD40LWg3H4/hqdefault.jpg
    https://cdn7.bigcommerce.com/s-9t4wk...=2&imbypass=on
