Haven't picked a cam yet, but beforehand I need to full understand whether I need to go with 1.6 or 1.7 roller rockers on my aftermarket heads.
Heads are the AFR 165cc Renegade heads.
I'll be using a GT40 intake that's been ported and polished with a 65mm throttle body that's been polished.
I've got 3.27 rear gears.
How much cam is too much with the "stock size" 1.6 rockers, whereas what would be too much for the higher lift 1.7 rockers.
Not revving to the moon as I'll be stock bottom end this go around. So I'll be wanting a non-stock HO firing order cam, but don't know what to pick here.
Basically, what's going to make my car pull hard across the usable RPM range, I understand the heads may be overkill, but the price point says I have to get them.
