Results 1 to 8 of 8
Thread: starting off in 2nd gear..90 AOD
  1. #1
    Default starting off in 2nd gear..90 AOD
    So it seems like the car is starting off in second gear from a stop. What could be the cause? If I pull the gear lever all the way down (2) I have 1st gear and if I floor it in second with the lever in (D) it down shifts into 1st. Any ideas?
    Thank you
  2. #2
    Jan 2008
    New Jersey
    3,111
    hmmm sticky valve body?
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
    40,167
    I had that problem with a totally different trans and it was garbage in the governor. With your other low rpm shifting thing, I wonder if thats not the problem.
  4. #4
    Thank you Brown Muscle and Gadget. I'm going to have a look into it this weekend.
    Might be time for a set of wide ratio gears and a little higher stall converter along with a rebuild.
  5. #5
    Mar 2006
    Bedford, VA
    6,197
    Definitely some junk in there somewhere.
    I lost first in my 88 for about a week. It was cold AF and I guess condensation froze it up. I did not have any access to first, manual, downshift, nada. First came back after a long highway run (two hours) and lived happily ever after for the next 12 years (until 1-2 started to slip).
    Do not do a trans flush.
  6. #6
    40,167
    easy enough to remove and inspect the governor. Just pull the tailshaft and its under there. If I remember right the actual working part just unscrews from the part that mounts it to the tailshaft. Not much in there, spring and a piston basically. Make sure its not packed up with trash.
  7. #7
    Sep 2008
    Whitestone, NY
    19,987
    You can see some of the governor in this thread:
    http://www.grandmarq.net/vb/showthre...l=1#post775133
  8. #8
    Thank you David.
    Today I put some Seafoam for transmissions in, hoping to free up any sticky valves. I drove it around for 33 miles in neighborhood conditions. I manually shifted from 1-2 many times during this outing. I found an open stretch of road and laid it into it a couple of times. Once manually shifting from 1st to 2nd and also in D and letting it shift by itself. Each time in 1st gear it laid 2 patches of rubber down about 3 feet long and chirped second. I'm just going to drive it like it is and prepare for a rainy day and get a performance transmission or parts when time calls.
    On a side note, on the back road I got to watch a 70's Challenger get it on thru the gears, It was a built beast and defitinely a big block. The tires got skinny when he took off and he wound it up in each gear. Sad though, I think it was an automatic.
