Decked Block - Strange Looking Artifacts
    I just got my '79 351W block back from my friend's machine shop. I had him deck it down to 9.460" (.020" less than an early block). I didn't notice anything unusual when I picked it up; I saw it later when I got home and put it on the stand. He probably can explain, but figured I'd ask here first. Remember this is my first "Phord" build... ;-)
    There are three or four spots (I'll go back and take a pic later if I have to) about .25" diameter on each bank around the inboard cylinders that look like they were plugged or welded. You can just barely see a round shadow and indication of slightly dissimilar metal in the freshly machined surface. There was no evidence of this when I pulled off the heads, I cleaned off the old gasket and sconge with a blade, but I didn't clean it spotlessly. I don't think this block has ever been decked before, it was nominal for a 9.503" smogger. Were there some extra coolant holes that were maybe filled in by Ford or someone else along the way? This was a totally stock (but once rebuilt by person(s) unknown) motor with the factory '79 "wheez-O-matic" D8OE heads. Nuthin' special...
    I don't think it's gonna make a bit of difference, but I'm just curious.
    United Socialist States of America
    (occupation government)
    I'm not exactly sure what you mean, if you could take pictures it would help. I didn't have anything like you're describing on my 82 or 96 block, as far as i know
      Yeah, I'll do that later. I know yours doesn't have, I looked at your extremely high-resolution pics and zoomed in! I don't know if my camera's going to pick them up, but we'll see. By the way, my coolant hole layout seems exactly like yours, going by memory. I DID notice there are some holes in that gasket you're using pretty much exactly where I'm seeing these strange looking areas. I haven't gotten my gaskets yet, probably going to use the Edelbrocks since I'm running their RPM heads.
        It's no biggy, i really dont know what they are, i assume it is a joint line between some casting cores in how they assemble in the mold cavity.
        9.485 deck height on a D4 block.
          Fresh D1 block on marketplace, you can see them too. https://www.facebook.com/marketplace...2053584574630/
            they were on my 82 block as well
              Thanks, everyone. According to my friend @ the machine shop, they see them all the time on Ford blocks. Nobody really seems to know what they are, I was thinking something as JeffBoudah suggested. Pardon me, I'm just not used to Ford strangeness, superior old-school (50's/60's/70's) Chrysler engineering is my usual "wheelhouse".... ;-)
