Hello all, so here's the low down. I just pulled my engine out or my 1989 MGM, regasket EVERYTHING, did a 86 GT cam (advanced 4°), touched up E7 heads, explorer intake, Lightning throttle body/spacer, and the 90ark VII ECU. I got the engine in last night, EVERYTHING hooked up. I get excited for first start(mind you I was a idiot and been up past 24+ hours to get this done), I slap the battery in, and my dumba** made thee biggest rooky mistake and hooked my battery up backwards. All fuses under the dash are fine, interior lights, fuel pump, dash lights, radio all work. key cycles and can here everything work. Ingo to crank and no click. I'm sure I blew a fuseable link, my question is where should I start to check? Any main ones to check first? ECU fried now? Alternator and wiring all junk?
I'm BEGGING for some help, pleeeease?! I thank all responses, don't be afraid to call me a dumba** or anything else you please, I more then deserve it.
