Hello all! So I did the 5.0 HO swap on my 89 MGM. Car runs good (after a mishap of getting excited and putting battery in backwards. I'm a idiot I know lol) but I have some questions if anyone can help.
So for the build I did E7 heads (some bowl and port work/smog bumps removed), 86 GT cam (advanced 4° at crankshaft), explorer intake, lightning throttle body/spacer, mustang shorty headers, custom 2.5 x pipe, Borla Pro XS mufflers, factory 2" tailpipes.
My question, since I have my camshaft advanced 4° at the crankshaft when I go to set base timing (engine warmed up, spout connector out) the car runs like crap with base timing at 14° Advance(which I thought was alot when cam is set at 0/0). When I bump it all the way to 20° base timing it runs great (no back firing, no knock/ping) and actually has some power out of the hole with the weak 3.27 rear gears.
So is 20°Advance to high for base timing even tho I'm having no I'll side affects? Is it taking so much base timing since my camshaft is advanced?? I can bump it all the way to 40° Advance base timing at idle and I still get no knock/pinging, backfiring, or anything reving or even when turned off and spout connector plugged back in and taken for a drive. Is my TFI module trashed or what?? I'm stumped why it's being weird.
Sorry for the long read, just want to be thorough. Thanks for all replies in advance.
