Results 1 to 7 of 7
Thread: locking nuts for upper control arms
    It's all about the Benjamin! monterey1962's Avatar
    Arctic Wasteland
    5,843
    Default locking nuts for upper control arms
    I plan on replacing the front control arm bushings on my '89 CV LX. Does anyone have a set of the locking nuts needed for the upper control arms? As I seem to have read, the originals are not re-usable.
    Jan 2008
    New Jersey
    3,199
    I have a few, but to be honest you’d probably do just as well ordering them from where I did: https://www.grainger.com/product/FAB...ock-Nut-29DU72
    Jan 2008
    New Jersey
    3,199
    I torqued them to spec and one actually came loose...so I'd use the locking nuts AND lock tite...
    22,569
    I ended up using some jam nuts on a couple of the pinch nuts I got because they wouldn't hold.
    Jun 2006
    Holland,MI
    547
    Um.... isnt that a metric thread? M16x1.5 is dang close to 5/8-18 like within .005" on both diameter and pitch.
    40,737
    Would make sense for it to be metric, all of the other body and suspension hardware is. Wasn't something I considered at the time, the sticky on here I think specifies 5/8 fine.
    McMaster-Carr is my usual go-to for hardware. Also just seems to be better quality than the stuff I get from Grainger at work.
    I think I'm using 5/8 hardware on mine, McMaster sourced, and it hasn't come loose in the almost 15 years its been on there. When I re-used the original nuts they came loose almost immediately.
    Arctic Wasteland
    5,843
    Thanks for the info, fellas.
    I went ahead and ordered nuts from McMaster-Carr. Ordered body mount bolts, too.
