I was thinking that at some point I'd want to replace my factory 14" steelies with a set of HPP wheels. However, I wasn't sure how well they'd fit, whether to get the 15" or 16" version, or what size tires would fit best in the case of the 16" wheels (I know a good size for the 15"). In either case, I figure that I'd want something with a width of 235+. Any thoughts on this?
HPP Wheels on '79 Marquis Coupe
The 16 x 7 will fit and look great. They have a 4mm offset which is less than 1/4". I kept mine as they'd look great on a early Mustang. I'd run a 225/60-16 or 235/60-16 tire.No ... I'm not arguing with you ... I'm just explaining why I'm right ...
What are the 15" versions you are referring to? I am only aware of hpps wheels in the 16" variety.
If running the stock front brakes the hpp center caps most likely will not fit. I believe some have circumvented this issue by grinding down the hub snout and even some of the inside of the centercap.~David~
Thanks, everyone. Glad to have the input. And I think maybe I got confused on the size of the HPP wheels because some sellers I've seen listed them as 15".
Speaking of the center caps, I haven't seen any around. Where should I look?1978 Ford LTD wagon, 351M
1979 Mercury Marquis, 351W
1987 Ford F-250 HD 4x4, 460, 4-speed, reg cab full bed
2003 Mercury Marauder, 4.6L DOHC, JLT CAI, 4.10 gears, J-mod, custom tune
Can find a few on ebay...
https://www.ebay.com/itm/28413566255...AAAOSwWu1f8PdC
https://www.ebay.com/itm/35205381003...8AAOSwstxVbQru~David~
I thought there were some 15" Lacey Spokes before 1998, polished aluminum rim area maybe, not silver metal-flake like my '01's 16x7 versions?No ... I'm not arguing with you ... I'm just explaining why I'm right ...
https://www.ebay.com/itm/35205381003...8AAOSwstxVbQru1978 Ford LTD wagon, 351M
Originally posted by massacre View PostI have (2) 15” lacy spoke MGM wheels with center caps. They are not HPP wheels thoLast edited by tbear853; 05-07-2021, 10:30 PM.No ... I'm not arguing with you ... I'm just explaining why I'm right ...
Real HPP's only come in 16", but they come in three distinct flavors. (93-96, 97/98, 99-02)
Lacy spoke 15's are similar, but certainly not HPP's.
16" LSC Lacy spokes are pretty much HPP's with a different offset (and require spacers, though will fit an 03+ just fine)
225/60/16 is stock, 235/60/16 will fit fine, 255/50/16 will also fit but is really pushing it width wise on the wheel. I've ran all three.
Stock HPP center caps will fit the stock brakes with a little grinding and hammering.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by ledzilla View PostThank you. I only saw that gold-ish one and wasn't even certain it was the right kind.~David~
Originally posted by tbear853 View PostWhat makes a HPP wheel?86 Lincoln Town Car (Galactica).
I know what a "HPP car" is, but "what is a HPP wheel" ... was more my query. Like, if the HPP wheel is laid on a pile of other Lacey Spoke 16x7s off of non HPP cars, how can a fellow tell the difference? I've got a set of Lacey Spoke 16x7s off a '01 CV, they have exactly the same 4mm offset as the 16x7 Teardrop wheels that were on my '01 Mercury. I've seen three variations of Lacey Spokes which did usually come on a HPP car, but were not exclusive to HPP cars. I only asked the question because I had never heard of them being called HPP wheels, just always Lacey Spokes.Last edited by tbear853; 05-08-2021, 01:29 PM.No ... I'm not arguing with you ... I'm just explaining why I'm right ...
