65 mm tb and 19 lb injectors
    I had TAVR done on Tuesday and came home 18 hours later. This technology is crazy awesome. This replaced my Aortic valve without having to cut open my chest. It only takes 90 minutes. I’m feeling great.
    Now I am ready to replace my throttle body soon.
    The set up is a 75 mm Pro M maf sensor 65mm throttle body with a 65 mm spacer going into A GT 40 intake along with GT 40 heads.
    My question is will the 19 lb fuel injectors be large enough? I currently have an HO throttle body and HO spacer on the same set up.
    This is in a heavy Colony Park with 3.55 in the rear.
    Ideally you want to know the injector duty cycle. If you're getting over 90% you want more injector to get some safety margin.
      In the Mustang realm 19# injectors are good to about 300hp, though that’s not a good reference point. I’d say you’re probably good but you have no room to grow. If you’re getting a tune you might as well go bigger and have it tuned for them. Just my 2 cents.
