Gain access
    Gain access
    So as I mentioned some A-Hole pushed in a portion of the drivers side q-panel (just back of the door lock pillar post). How can I gain access to the inside of that portion of the q-panel?......I want to see if I can pop out the dent made by someones bumper.
    take the carpet off the inside of the trunk on that area. That's about the best access as you'll get... and it sucks. If it's closer to the door than the filler neck, you may have to take the back seat out as well. If it's closer to the wheel well than the decklid, you might be able to get at it from the wheel well.
    If it's on a wagon... remove all the panels in that area unless it's closer to the wheel well lip and can be access from the wheel well. Never can remember all the cars everyone has without signatures.
      Its a two door model. Remove the lower rear seat and the lower panel below the quarter window. Its held in with push pins and in some cases some screws back by the rear seat back...may need to remove that too then.
      Be careful with the plastic panels that are in that area. Fragile and unobtainum.
        Ah... yeah... those interior panels on tudors are a bit of a PITA.
          Thanks Dave and Sly...I will give it a try...........I am just thankful the A-Hole did not hit the door edge and lock pillar post!
            Many thanks!
