Speed control doesn´t work on my 84 TC.
How to check the servo motor for correct vacuum? Shop manual only tells how to check the electric circuit.
I can get the actuator cable to retract by applying vacuum to the port that faces the front of the car (the short c-line is connected here)
Steering wheel switches work
Steering wheel brushes clean
Wiring to amplifier ok
Dump valve works and correctly adjusted (1,27mm shim to adaptor plate)
Vac lines new
Speed Sensor reads required 200ohms
Still no cruise.
Vac lines new
Still no cruise.
