Mufflers are you using.
    Which mufflers are you using?
    Do you like them?
    I have 2.5" offset offset magnaflows. I purchased them used from a mustang guy. I imagine they were for a mustang. I like it. It is not too loud.
    Another video here of driving and such: https://www.youtube.com/watch?v=huLP...e=emb_imp_woyt
      I have magnaflow offset/offset glasspacks as well. Thrush turbo welded glasspacks I think are the less expensive brand version of magnaflows.
        On my MGM, single 2 1/4" exhaust no muffler just the stock cats. Still was fairly quiet with a pleasant volume level.
          Magnaflow they are. Drone terribly they do. Oddly phrased your title is. Annoyingly written my response must be.
            Yes... yours done horribly. Mine don't drone at all. I was shocked how bad yours drone.
                I've run drone masters, they drone. Just don't.
                I currently have 2.5" summit "turbo" mufflers on the wagon. I think they sound great, but my compression is lil higher...
                IMO firing order is the biggest gain for a sweet exhaust note. 302 sounds like a tractor. HO/351 sounds mean.
                  Depends on what you want. I like the Dynomax Super Turbos because I like quiet exhaust systems nowadays. I'm running cats and 3" Dynomax 17792 mufflers on my 351W; but I haven't started that engine yet; so I have no critique of how they sound. I was running Dynomax 17749 muffs with the lopo; behind a full exhaust. They were very quiet.
                    I'm running Borla XS on my cars.
                    I don't like to draw attention with the sound at WOT. They do get a little louder when you open it up, but not enough to draw the police from a mile away.
                    They do well and have no horsepower loss. They actually have a slight gain in horsepower.
                      Almost always if not stock, some turbo mufflers.
                      Once bought a truck that had a FM 3SI/2.5DO, drone was bad at some speeds, a glasspack ahead of it helped.
                        I'm currently running some Flowmaster delta flows that I got for free on a custom bent 2" system with the two rear cats removed. It sounds good for what it is.
                        When I put on a new exhaust, it will consist of BBK headers, Pypes X-pipe with high-flow cats, and Walker QuietFlowSS 2.5" mufflers with Impala tailpipes. I have a good feeling about how that will sound.
                        —John
                        1985 Ford F-150 XLT Lariat
                          ^^^^^^^^That will be quiet; basically the same setup I had with the lopo; except I had Summit turbos at first; then Dynomax 17749 muffs when they failed. It was quiet with the Summit turbos; so much that my Mom hated it; which is why I had to put cutouts on that exhaust.^^^^^^^^
                            I've mellowed out a lot and actually want a quieter car, but still with a bit of rumble. The new exhaust will also coincide with the new engine I'm having freshened up for it: 302 block, GT40 (non-P) heads, and a camshaft comparable to a '93-'95 Cobra. It'll essentially be a Cobra engine.
                            —John
                              pretty sure its the Fox H pipe. Fox cars are really prone to drone issues if things are not exactly so. The black Mark VII droned pretty badly too. Whenever that thing needs exhaust work again, or whenever I feel motivated to drive it more, I'll have stock-style exhaust made up for it. Probably a little larger than factory but using the Panther routing and such. I strongly suspect that will make the problem go away.
