which sender is for a gauge?
    I don't have my box to look at.
    with a 5.0 or a 5.7 IIRC there are two temp senders. One is for the engine control and one for the gauge. Which is which?
    Thanks
    Gauge is driver side right into the lower intake, single wire (stock) just in front of injector #5. Actually a temperature switch if I'm not mistaken. Engine Control is passenger side front corner, 2 wire, usually in some sort of tee-tube on Panthers coming off of the lower intake, not directly into the manifold like the picture below.
      Perfect. And such a pretty picture.
        Too bad it's not mine, LOL. I just found that in a Google search. Much easier to see that stuff in that picture though than on mine since the distributor and stuff is not in the way in that picture.
          It had the intake in the WRONG direction.
