Line Output Converter with Common Ground Head Unit
    I want to add aftermarket speakers and amps to my 1985 CV while retaining a factory head unit. I’m currently searching for a premium sound head unit with floating ground speaker outputs. In the event I can’t find one is it possible to hook a line output converter to a common ground speaker out head unit? Would I need to use a floating ground adapter that is hooked up in “reverse”?
    Personally I’d look for a slightly later head unit (88-89) and then go with the line out adapter. You have to run all new speaker wires anyway and getting quality sound out of floating ground with new amps isn’t going to happen.
    Past Panthers
      The 85 head unit has common ground on the rear and floating on the front channels, however you can use just the speaker + to ground and have it work fine, just at half output power.
      I don't honestly think the speaker to line adapter cares what the source config is. Its just a couple of resistors.
        Thanks! I thought all of the premium sound radios were floating ground on all 4 channels. Is there a big sound quality difference between the two?
        Also, if I were to go with an 88-89 radio with floating grounds on all 4 channels will it still properly mount in an 85? I thought something changed with that in the later years.
          The 88/89 should bolt up the same.
          Past Panthers
            Its mostly just a matter of power output. The common ground channels are rated for 12 watts, the floating are rated for 24. Going to a line-out converter, this doesn't matter.
            The mounting changed around 1990. If its got 4 holes in the faceplate for the release tool, those don't fit. Up to 89 they had the L brackets on the side and it just bolts in.
              For some reason I thought it was way more complicated than that. Good to know it’s just the power levels that are the only real difference.
              I ended up finding a decent looking 1988 radio on eBay a little while ago. Seller claims it works. I’ll find out when it arrives later this week. I also found an aftermarket set of pigtails with plugs for it. If it works in it goes! The digital tuner alone makes it worth installing! If I can’t easily break the common ground spice I’ll use a floating ground adapter with it until I can do the rest of the upgrades. When those come I’ll run a multi conductor speaker cable to the trunk where the line put converter will live.
                the way they get it done is actually sort of clever. The output of one amp feeds to the inverting input of an identical amp, so the voltage at the + and - end up equal but opposite in order to get more power. Its a trick straight out of a 1930s radio, but it still works.
                  That is a pretty cool trick. I’ve always been interested in audio equipment but never had the opportunity to learn the very technical side of it.
