Results 1 to 10 of 10
Thread: Dead Battery and Rapid Clicking Under Dash with Key Out
    Nov 2006
    Dirty Jersey Yo!
    8,517
    Question Dead Battery and Rapid Clicking Under Dash with Key Out
    So my battery died overnight. Drove home from work yesterday just fine; go out to start her up this morning and click. Take the key out of the ignition and there was rapid clicking coming from under the dash for a minute or so after the key was taken out. I read PICKUP6772's thread about what seems to be the same noise coming from the same area; just that mine did it while the car was powered-off. Not sure what to make of it.
    Member tbear853's Avatar
    Jan 2021
    Virginia but I started life in Texas
    109
    I've had batteries go just that quick. Once had one in my '95 T-bird go out after being parked over a couple days, just suddenly heard noise in trunk area on left, module under deck. Car would not even click with door fob, battery dead. Do not know how that module was making noise. New battery fixed it.
    40,737
    ....in what ?
    Nov 2006
    Dirty Jersey Yo!
    8,517
    My '05 Grand Marquis
    22,569
    If the battery is bad like that it will float voltage back up to a level to trigger some keyless entry stuff but as soon as that triggers the battery drops out again and the process repeats ad nauseam.
    Jan 2021
    109
    I think that is what was going on on my '95 T-bird LX as I recall a mechanic buddy explaing it, seems to me now that you mention it ... that is the module up under the left side of rear shelf, in trunk. My '92 had the keyless entry number pad, but no remote capability but the '95 does have remote too.
    22,569
    In the 05, it should be the LCM relays making noise trying to trigger the parking lights because the keyless entry system is triggering them. Not sure about the 95 or 92 though.
    I once had a battery that was marginal. If the engine was only shut off for an hour or two, the car would crank back up, no problem. Longer than that, and it would lose enough voltage that one of the relays wouldn't stay latched open, and that turned on the HVAC, even if the key was off, at whatever blower speed was set before the car was switched off. This happened during the summer, so the blower motor was perpetually set on MAX and ran the battery the rest of the way down pretty quickly after that.
    A new battery ended up curing the problem for me, but you might want to also swap the relays into different sockets to see if the clicking moves to whereer you moved the relays.
    PROUD DADDY OF JILLIAN PICKUP6772's Avatar
    Jun 2005
    MASTIC BEACH, NY
    770
    Packman,
    My TC was doing it with the key out. It turned out to be a bad passenger blend door motor on mine. When I removed it, It was an aftermarket DORMAN motor. I replaced it with a MOTORCRAFT part, and all is well. Also, I would load test the battery. ANYTHING over 5 years old, no matter how good it test, or looks, should be replaced.
    MIKE
    Nov 2006
    Dirty Jersey Yo!
    8,517
    Battery was replaced. I looked in my old notes (before I got a dedicated car maintenance notebook) and found that the old battery was installed 4.5 years ago. I will look into the blend door though; maybe the old dying battery affected it somehow.
