Results 1 to 20 of 20
Thread: 1990 Country Squire Fuel Pump
    Default 1990 Country Squire Fuel Pump
    Hi all. Iím new to the group and new to the panther platform. I just purchased a 1990 country squire wagon last week at auction for 1100. The car had been sitting for 8 years. I know the fuel pump needs replacing and I was wondering if I could replace it by cutting a hole above the tank in order to get to it? Thanks.
    6,463
    Welcome!
    Drop the tank. You'll likely need to refresh that one or get a new one anyway.
    Dropping the tank is no fun but not that bad. Can be done easily in an afternoon.
    I revived my 1990 wagon from an eight year slumber in 2016. The inside of the tank looked like the wreck of the Titanic.
    I love this car, the kids love it too. I suppose youíre right and I should just drop the tank. Wish me luck! Thanks again.
    GMN Regular WagonMan's Avatar
    Bridgewater Ct.
    814
    Hi, Welcome! I am WagonMan. I have parted several box body cars and I have a ton of parts.
    LMK if you need anything. Where are you? I don't sell out of the continental U.S.
    1990 Colony Park
    1970 HEMI Superbird
    Thanks for the help! Im in New York, as I work on this Im sure I’ll need some parts. I’ll definitely reach out to you, thanks again!
    I just ordered a brand new tank from eBay, what the heck.
    22,570
    Be sure the tank is specifically for a wagon as the sedan tanks are different.
    So I replaced the fuel tank and fuel pump. The car runs great. However the unit that measures fuel level isn’t working(gas gauge reads past Full). I can’t find this unit anywhere to purchase. Anyone have a lead on where I can find it?
    22,570
    I did this on a fuel gauge once. The cluster connector was loose and wasn't reading the sender at all. Plugged it back in all the way and it fixed the issue. So you might have a loose connection somewhere along the line.
    Where are there connections along the line where I should look besides the cluster itself? Thanks again.
    Bridgewater Ct.
    814
    Is the fuel gauge reading above full all the time? Does it go to "E" when you turn the car off?
    WagonMan
    1990 Colony Park
    1970 HEMI Superbird
    It stays on F no matter if the key is on or not. Maybe the gauge itself? When I first put the key on it drops a bit to 3/4 then immediately goes back to F. I pulled the connector at the tank and the gauge behaves the same way whether itís plugged in or not.
    Quote Originally Posted by WagonQueen View Post
    It stays on F no matter if the key is on or not. Maybe the gauge itself? When I first put the key on it drops a bit to 3/4 then immediately goes back to F. I pulled the connector at the tank and the gauge behaves the same way whether it’s plugged in or not.
    Also, the gauge didn’t behave this way before I changed the tank. It definitely wasn’t pinned past F.
    6,463
    I'd say the wire picked up a ground somewhere. Maybe it got squeezed somewhere?
    The fuel gauge sending unit was really rusty and I soaked it in some CLR and replaced the float. I also sprayed wd-40 all over it to loosen the float arm. Maybe I damaged the unit by doing that?
    Bridgewater Ct.
    814
    Turn the key on, Let the gauge go up to full. LEAVE the key on and unplug the sender at the tank. It should immediately drop to "E". That will tell you the sender is no good. If it stays on full, then you have a short in the wiring. WagonMan.
    1990 Colony Park
    1970 HEMI Superbird
    Quote Originally Posted by WagonMan View Post
    I just did that test and the gauge stayed on Full. Maybe I damaged some wiring getting the old tank out or putting the new tank in. Also, I cut two access panels out from behind the rear seats to get the rear shock absorbers out. I wonder if I did any damage to the wiring I saw. It’s raining cats and dogs out here today so I’ll check it all out tomorrow and let you know what I find. Thanks again!
    Ok so I corrected the wiring issue. Thanks he sender must also be the issue because it reads Full no matter what. However now when I disconnect the wiring the gauge pauses. I’m having a hard time finding a gauge level sending unit for this car, are there any universal units that might work?
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,084
    I would go to the Ford dealer. Get the part number. Run the number on "Rear Counter Auto Parts". If nothing try Ebay, Green Sales.
    There are a few more suppliers. You have to have the proper number though.
    6,463
    Revive it. Very rare sending unit. http://www.grandmarq.net/vb/showthre...air&highlight=
