Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Monty's 1978 Case 446
    It's all about the Benjamin! monterey1962's Avatar
    Arctic Wasteland
    5,865
    Default Monty's 1978 Case 446
    I bought this tractor last year. It had a bad engine knock, and I was dumb enough to buy it for $1,100 (came with a front blade). That price with a bad engine was a rip off. Tore the engine down to find that the rear main bearing was wiped out, and the oil pump had self destructed. Doing a full rebuild, and I'm $300 deep in parts. Spent yesterday and this afternoon cleaning everything and honing the cylinders (pic below). A flex hone and diesel fuel worked pretty good. If I can actually get this thing to run good, I'm either going to build a loader for it, or buy a Johnny Bucket.
    Attached Thumbnails Attached Thumbnails c07.jpg   c06.jpg   c05.jpg   c04.jpg   c03.jpg
    40,850
    was thinking that looked like an Onan, then I saw the label. Onan uses a very similar motor on generators, exists in air and water cooled versions.
    wonder if someone ran it out of oil or just let it get nasty until the pump gave out. These things are usually pretty reliable.
    Arctic Wasteland
    5,865
    It is an Onan B43G. Oil pump gears were in pieces and the housing was cracked. I'll have to remember to get pics of the damage. Story I got was that the guy was blowing snow and the motor started knocking. Someone had put an electric fuel pump on this tractor, too. I plan to go back to a manual pump.
    Did some assembly. Installed crank shaft, cam shaft, pistons, and valves. I'm not too confident on the rear journal of the crank shaft. There was some damage from the bearing failure that I tried to clean up.
    Sep 2014
    Warren, MI
    6,590
    You a fan of mustie1 on YouTube? He has a lot of tractor teardown & "will it run?" type stuff. This would have been a cool teardown to watch.
    Arctic Wasteland
    5,865
    I'll have to check out that channel.
    Did more assembly, tonight. The "new" used oil pump did not want to fit, so I ended up filing off some extra material from the housing where it was molded. Had a lot of extra material there, and needed a sharp corner rounded off. There are signs that someone has been in this engine before: The old oil pump has grinder marks on the top side where the housing cracked, and the two bolts that mounted the pump were not factory bolts. Installed heads, oil pump, oil pan, flywheel, and some little stuff.
    Sorry for the lack of pics, but I don't really like to stop and shoot every little thing. I like to get a pace going and keep on it.
    Pics of the rear main bearing and old pump below.
    40,850
    am I looking at teeth that should be on a gear and a cracked housing? how does that even happen?
    Sep 2014
    Warren, MI
    6,590
    That's my problem with pics and video. Ash and I were going to try and start a YouTube channel with that van we bought. Then we forgot to film a lot of it so we were like, F it.
    40,850
    I suck at that too. The people that are successful at it put a lot of time and work into it. I can appreciate it, but I can't be bothered to commit to that much effort. Especially with the ad revenue how it is, there is such an amount of work that has to be done before there is even a chance of making any money and unless you're at it constantly and/or get really lucky its basically a lot of work for nothing. I have a channel purely for convenience reasons, its all zero effort "this is how to do a thing" type stuff that a half dozen people watch but its handy as a place to dump that sort of content.
    22,607
    I made $142 over 10 years before Google cut off the adsense tit for those with less than 4000 subs.
    Yeah... I didn't spend it all in one place.
    Arctic Wasteland
    5,865
    Pulled the flywheel and timing cover back off, tonight. I had a bad feeling about a steel ball I had seen in the block that didn't match up with my engine manual.
    Picture of block with oil passages: The ball was jammed into the center oil passage hole. I removed the oil pressure bolt, spring, and valve, but couldn't push the ball out from the back side. It was really jammed in there. I took a chance and used a hammer and punch to knock it in, hoping I could dump it out with the engine upside down. It jammed on the other side of the oil passage. Gave it a couple more hits and "plink" into the oil pan it went. *WHEW* Had to pull the oil pan off, but I got it out.
    Picture of timing cover: That ball is actually the ball bearing for the governor shaft. It sits in a hole perfectly where the arrow is pointing. Why ... the ... hell ... was it jammed into an oil passage in the block?!
    Picture of mystery pin: No idea where this thing goes. I thought it came out of the timing cover during disassembly, but there's nowhere for it to fit.
    Picture of old oil pump to show grinding marks and more gear remnants.
    6,502
    Engine tear down after a failure is very interesting. Good job so far. Do you have a good service manual to help you out on the mystery pin and reassembly?
    40,850
    wonder if someone was in this previously and thought that since the ball could fit in that hole, thats where it went. Assuming the governor didn't work with missing parts either. Grinding marks on that pump look more like angle grinder, not internal self-destruction sort of grinding.
    Arctic Wasteland
    5,865
    I purchased a reprint of the original Onan B43G manual. I also have a copy of the Parts manual and Operators manual for the engine and tractor.
    Arctic Wasteland
    5,865
    Governor rotated before, but now it rotates much smoother with the ball in there.
    Arctic Wasteland
    5,865
    I've come to the conclusion that the mystery pin does not belong to this engine. Doesn't fit anywhere, and not in the parts manual, as far as I can see.
    6,502
    Quote Originally Posted by monterey1962 View Post
    Scary. Whoever was there before hopefully didn't ruin it from being revived.
    Donating Member massacre's Avatar
    Oct 2011
    USA
    421
    That is a cool tractor
    Jan 2008
    New Jersey
    3,212
    This is a fun/neat project. Looking forward to seeing more of your progress with it!
    Nov 2006
    Dirty Jersey Yo!
    8,535
    Nice! At first glance, I was thinking Explorer 5.0 swap LOL
    Or maybe not LOL
    Arctic Wasteland
    5,865
    V8 swap you say? Hmm.
    I pulled the rear main bearing cover off because I was concerned about the crankshaft journal that I had cleaned up. I don't know what to do with it, other than run it and see what happens. They sell downsized bearings, but I didn't really feel like messing with taking it to a machine shop. Hoping this doesn't bite me in the ass. Rear bearing has a few scuffs on it from when I originally test fit it before cleaning up the crank.
    I was going to rebuild the carb tonight, but upon disassembly, I found what looked to be a recently rebuilt carb. Gaskets looked good and were not brittle. Everything is clean. I reassembled it, and plan to run it as is.
    The mechanical fuel pump was bypassed by a previous owner. This tractor has an electric fuel pump mounted under the tractor, and a mess of wiring to go along with it. I have no idea how this mechanical pump works. Need to do some research on hooking things up.
    Edit: This is a pretty good video on this carb. https://youtu.be/yaoJHdrl3kQ
    Attached Thumbnails Attached Thumbnails c15.jpg   c16.jpg   c17.jpg   c18.jpg   c19.jpg
