Anyone have the correct torque specs for fuel pump to tank? I've seen some ranging ideas but want to be sure I get this right the first time. It is an OEM Motorcraft pump going in.
Fuel Pump torque specs for 2003 CV LX
89 inch lbs. tighten gradually in a star pattern03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Thank you for that info! I'll add that to my how-to list.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
