Ok, I just got done installing a brand new Ford fuel pump assembly and fuel filter. Turn the key a few times to prime the system (which I hear the fuel pump run EVERY time), CEL light comes on with KOEO and then goes out as I crank it. Doesn't fire at all.
I've verified spark. Checked all fuses and swapped the FP relay with the horn relay. No codes stored for failures.
I rented a fuel pressure test kit and stuck it on the rail. I am seeing 0 pressure when it primes. Obviously it won't start. I've primed it several time and still nothing on the gauge.
Anyone experienced this one before? My next step is likely going to be to pull the outlet line off the fuel filter and prime it again and see if I get fuel from it. If not, then I guess I'm going back into the tank unless someone has a better idea...
