Results 1 to 2 of 2
Thread: 1989 MGM headlight switch wiring diagram
    Member Not_your_grandpas_marquis's Avatar
    Nov 2016
    The Rust Belt
    59
    Default 1989 MGM headlight switch wiring diagram
    So I had to do a heater core replacement and in the midsts of unplugging everything for the dash removal, the headlight switch GRENADED from being old when I went tried to unplug it.
    Now I'm left with a bunch of wires and have no clue where they go for the switch so I can repin them to the new connector since the new connector doesn't have the same wire colors.
    Can't move forward since I need the plug done before I slap the dash back together.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,490
    If you do not have auto headlights, you'll have less wires.
    and if you havn't discovered it yet, you can depin the new connector and insert the original wires into new block. Just inspect the parking/running/dash light connector closely, thats the one that usually melts down and corrodes.
Tags for this Thread
