Results 1 to 12 of 12
Thread: Transmission oil cooler
    Default Transmission oil cooler
    Any tips or ideas on an external transmission oil cooler
    Member tbear853's Avatar
    Jan 2021
    Virginia but I started life in Texas
    109
    I have an auxiliary cooler on my '95 T-bird, my '01 Mercury GM, my '77 F-150, and my '07 FX4 has a large factory one with it's heavy towing package. The one on my '77 has been on it since the late 1980s, it is behind the radiator but ahead of the fan. The Mercury and T-bird got their's maybe 5-6 years ago. When I add one, I add it in the return line to the transmission. I also use at least 2, often 3, and maybe sometimes 4 ... screw type hose clamps.
    5 is OK too.
    Reminds me, I should order some new trans lube fluid rated hose for the truck, getting some age on it.
    Nov 2012
    Shelby Township, MI
    3,619
    I have a Hayden 699 that I will probably get around to installing next year. I found cooler mounting brackets from certain GMT400 trucks ('88-'98/'99) with the Hayden 699 look like it will be really close to a perfect fit.
    Gone but not forgotten:
    Donating Member
    Oct 2011
    USA
    378
    This is a page from B&M catalog
    Jan 2021
    109
    On my '01 Mercury GM, the '95 T-bird is simular.
    Attached Thumbnails Attached Thumbnails cooler under.JPG   lines for cooler.JPG
    22,576
    Here's what was on my 93 and the current one I put on. Hayden 678 cooler. It's overkill for sure, but this car was my tow rig at the time, so I went with "it ain't done until it's overdone." The old cooler was put on by the trans shop that rebuilt the trans at 106K miles. I now have almost 260K miles on it and just needed to replace the torque converter once around 200K.
    Cake has an upgraded trans cooler (a real one now) and trans fluid temp gauge.
    old cooler:
    Attachment 47366
    new one in:
    Attachment 47365
    Temp sensor:
    Attachment 47367
    Gauge:
    Attachment 47368
    Nov 2006
    Dirty Jersey Yo!
    8,519
    I used a Flex-a-lite transmission cooler with the -6AN fittings. I'll get the part# for it when I get home as I can't find it on their site.
    http://www.grandmarq.net/vb/showthre...oria-LX/page18
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,092
    I have used the Hayden cooler. They work good. My favorite is a Crown Vic. Police package cooler. Complete with the mounting brackets and fittings. Fairly cheap if you get one from a Pick a part type wrecking yard .
    Member sluggish91's Avatar
    Jun 2018
    California
    113
    I also run an auxiliary transmission cooler in my 85. It was an inexpensive addition, easy to install, and serves for some peace of mind.
    1985 2-Door
    CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
    Donating Member
    Oct 2011
    USA
    378
    I have the B&M hi tek with a fan, the bigger model. I have a high stall converter and 4.10 gears so i want to make sure atf stays cool. AN-6 stainless lines and fittings. Also have a deep pan and temp gauge.
    I had it mounted in the Panther and it was fairly easy with plenty of room.
    I am actually trying to fit it on the zephyr now and it is much more challenging. Very little room because of the older style bumper and nowhere to hide it.
    I really appreciate all the help I also forgot to mention that I have a 88 tc stock... gonna play with the stock block before I eventually swap engine and trans
    22,576
    I did the same cooler setup (no gauge) on the 88 MGM I used to have.
