Results 1 to 6 of 6
Thread: Box steering column spring for shifter
    Default Box steering column spring for shifter
    How does the shifter spring in column come out?
    My shifter is loose forward and backwards shifts into gear fine
    Itís a 79 Marquis and there is a 88 Ltd at junkyard for parts
    Donating Member
    Oct 2011
    USA
    375
    I have a 79 shift column here, but it's from a fox body. I can take a look if you think it will help
    40,737
    I don't know if the 79 one is different, but I've done this on an 86
    Take the shrouds off the column so you can see it
    Shift lever comes off. Should be a pin that retains it. I think it drives up from the bottom then the lever will just pull out of the hole.
    Once thats out you should be able to remove the bracket that holds the spring. Been a while so memory is fuzzy here but I think there is one screw holding it, the L shaped piece comes out, then you can pull the pin with the spring around it off. Once the covers are off its pretty obvious how its held in there.
    Fox does look similar setup
    I think if shifter is on column
    Ok was at junk yard a 88 there got other
    Parts might go back and try again
    Donating Member
    Oct 2011
    USA
    375
    So here is a pic of my fox body shifter spring
    Looks like a couple of torx or allens to remove brackets and the spring.
    Might help you, might not.
    Just wanted to follow up
    40,737
    Looks about the same as the Panther one if I remember right. Its not real complicated, once you have eyes on the thing, figuring out how to take it apart is pretty obvious.
