Results 1 to 8 of 8
Thread: Seized Calipers
    Nov 2006
    Dirty Jersey Yo!
    8,519
    Question Seized Calipers
    I've not dealt with this before. The passenger side caliper on the CV is seized shut. I had a fluid leak in the master cylinder when I 1st installed it; due to an incorrect fitting. Corrected the problem and filled it back up. I should have bled the brakes at the time, but I focused on other things. Can I unseize the caliper by bleeding it? Is there another way to unseize that caliper? Or is it trash? Somewhere down the line, I will be overhauling the brake system for the big(ger) brake upgrade. Just need to move the CV for now.
    Jan 2008
    New Jersey
    3,203
    it's possible it's the sliders that got stuck too, and not the piston. Take the slider bolts out and see if you can move the piston with large channel locks, even so I wouldn't risk it, remanned calipers are cheap, locking up 1 wheel on the highway and flipping the car is not so cheap
    Jul 2019
    Finland
    1,030
    If the pistons don't move freely, rebuild or replace the calipers. If you manage to unseize the piston, make damn sure it keeps moving freely and evenly, they will easily stick again.
    Box calipers seems pretty easy to rebuild, but getting a remanned one shipped to you over on that side of the pond isn't nearly as expensive.
    Nov 2006
    Dirty Jersey Yo!
    8,519
    I will see if I can unseize it; if not, I will just get another caliper. I just need to move/push the CV to the other side of the yard; or have it pulled onto a flatbed.
    Jan 2008
    New Jersey
    3,203
    you should be able to get it unstuck enough to move it around unless it's REAL bad. I know when i rebuilt my original calipers the pistons were pitted like crazy, i got lucky nothing bad happened
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,353
    I had a caliper seize on me with my CV a few years ago coming home in traffic. Thankfully it was stop and go and not 65mph on the highway. It was a cheap reman from RockAuto that I put on a few years before that. It failed out of nowhere. I didn't risk reusing it because I muscled it home the few miles half dragging the tire the whole way. Picked up another one that was a step above their cheapest ones and didn't have any issues for the rest of the life of the car. (I might have actually replaced both sides just to be safe... I can't remember)
    Nov 2006
    Dirty Jersey Yo!
    8,519
    They're (calipers) 9 years old; but were only active for 4 of those years; as the CV has sat for the passed 5 years.
    40,747
    rust. Bleeding it ain't gonna fix it. Replace them or pop the pistons out and polish the bores and pistons. Put new seals in while you're at it. These calipers are pretty garbage about seizing up and sitting just kills them.
