I've not dealt with this before. The passenger side caliper on the CV is seized shut. I had a fluid leak in the master cylinder when I 1st installed it; due to an incorrect fitting. Corrected the problem and filled it back up. I should have bled the brakes at the time, but I focused on other things. Can I unseize the caliper by bleeding it? Is there another way to unseize that caliper? Or is it trash? Somewhere down the line, I will be overhauling the brake system for the big(ger) brake upgrade. Just need to move the CV for now.
Seized Calipers
it's possible it's the sliders that got stuck too, and not the piston. Take the slider bolts out and see if you can move the piston with large channel locks, even so I wouldn't risk it, remanned calipers are cheap, locking up 1 wheel on the highway and flipping the car is not so cheap-Phil
If the pistons don't move freely, rebuild or replace the calipers. If you manage to unseize the piston, make damn sure it keeps moving freely and evenly, they will easily stick again.
Box calipers seems pretty easy to rebuild, but getting a remanned one shipped to you over on that side of the pond isn't nearly as expensive.1985 Mercury Grand Marquis LS, "Maisa"
you should be able to get it unstuck enough to move it around unless it's REAL bad. I know when i rebuilt my original calipers the pistons were pitted like crazy, i got lucky nothing bad happened-Phil
I had a caliper seize on me with my CV a few years ago coming home in traffic. Thankfully it was stop and go and not 65mph on the highway. It was a cheap reman from RockAuto that I put on a few years before that. It failed out of nowhere. I didn't risk reusing it because I muscled it home the few miles half dragging the tire the whole way. Picked up another one that was a step above their cheapest ones and didn't have any issues for the rest of the life of the car. (I might have actually replaced both sides just to be safe... I can't remember)
rust. Bleeding it ain't gonna fix it. Replace them or pop the pistons out and polish the bores and pistons. Put new seals in while you're at it. These calipers are pretty garbage about seizing up and sitting just kills them.86 Lincoln Town Car (Galactica).
