I think a couple leaf spring clips are missing on that. Not familiar with a working Mark ash tray, but there is usually significant friction from the springs pressing against the sliders, and they probably double as retainers to keep things from falling out. That C bracket with the janky holes in the side may be where these springs where originally affixed. Might even have an underbracket that is missing that screws to the bottom of the dash to hold things together. As you might now, the ashtray assembly in a box is held in place by three screws, which leads me to believe something may be missing.
You have a castrated ash tray. There should be 4 balls in that slider assembly where the holes are blown out. Thats what sits in the grooves inside the dashboard. Thats also why it doesn't sit right or stay where it belongs. I think you may need a donor ash tray, that bracket looks pretty f'd up and it may not be possible to just put new balls in it. There are tabs that are supposed to capture the balls and it looks like yours have been bent or broken off.
The release is the tongue thing center top. Push it down and it slides right out of the hole. Putting it back in is slightly fussy but basically hold the tin slider thing towards the back with your finger and get it started, then the whole thing will just push right into the bracket with no real fuss.
I see what you’re talking about with the 4 holes where the balls should be. I’ll have to get a couple of pics of the ash tray assembly and see if it’s possible to see how bad the bracket actually is. If it’s not totally shot maybe I can just find the correct size ball bearings to go in there?
Taking a closer look at the ash tray it doesn't really look like the tabs that hold the balls are bent. It looks like the balls just sit in there and you kind of have to hold them in place while sliding the tray back in. I'll upload a couple of pics later tonight I'm at work right now and don't have good enough signal to do so. I just replaced the lighter socket in the ash tray so I pretty much have the wiring issue sorted out.
they hold themsevles in place if the tabs are not bent out.
[ATTACH=CONFIG]57066[/ATTACH]
Gotcha, this is what I have. There's a local you-pull-it yard with an '84 TC and a '86 Crown Vic. I'm going to go check them out Tuesday when I'm off and see what I can find.
likely, but if you take the thing to the hardware store, just get one size under the one that won't go into the hole in the bracket. Or use drill bits to size it.
I'm going to check out that '94 Town Car tomorrow and see if I can get that ash tray, if that doesn't work I guess it's off to the hardware store.
