Results 1 to 13 of 13
Thread: Transmission Oil Change? Yes or No
    Member Shayenne's Avatar
    Sep 2013
    London ON Canada
    56
    Default Transmission Oil Change? Yes or No
    So my newest member of my panther collection has some slipping transmission issues....
    The day I brought the car home, the transmission line broke. I noticed right away and pulled over, we fixed it then and there (it was fixed before and that fix broke), filled up the fluid and continued.
    I emailed the previous owner regarding this and he told me, it broke on him as well and he also noticed right away and fixed it. The car was not driven without transmission fluid. However the fluid that came out that day was brown. I am hearing different opinions on changing the filter and transmission fluid. Some say, DON'T do it you will f.... up your transmission! Apparently whatever is in the old fluid is needed in there and others say Go for it. The car only has 114000 km on it, original engine and transmission.
    What is your opinion on changing transmission fluids?
    1995 Lincoln Town Car Executive Series: "Albert" my daily driver
    1988 Lincoln Town Car Signature Series: "Don Vito Corleone" my Summer Cruise
    2004 Grand Marquis LS: "The Boss" with floor shifter (loved it) - R.I.P.
    1997 Crown Victoria: "Victoria, the Armadillo" R.I.P.
    2003 Lincoln Town Car: "Nikkatello" - R.I.P. (Miss you the most)
    1995 Grand Marquis: "Gustavo Gonzales, the dirty Mexican" - R.I.P.
    Jul 2019
    Finland
    1,076
    Just change the trans fluid.
    New fluid will always be better than whatever old crap is in there, as long as it's the correct fluid for the application.
    Lifetime trans fluids are bullshit and so is someone telling to not change your trans fluid.
    Sep 2014
    Warren, MI
    6,590
    Change it and the filter. If it breaks, it was going to anyway.
    40,850
    ^^ thats my theory on it. Never subscribed to the idea of running bad fluid to keep a transmission alive. I've changed several that were obviously way past due and had no issues with it. I think that "I changed the fluid and it died" thing comes from people who have a transmission thats got some major problem going on, they changed the fluid expecting a miracle, then it went ahead and failed like it was going to do anyway.
    Nov 2014
    Evans, GA
    1,875
    I've done fluid and filter on a handful of these cars, several of which were definitely a little "past due". Last one was a '99 CV that had a torque converter shudder and what I got out was nasty brown ATF. Car had roughly 200K on it. Gave it fresh Mercon V and it delivered appropriately firm shifts and no more shudder.
    As everyone else has said before, if you change it and it dies, it was already very much dead.
    22,608
    The clutches are probably worn out. The torque converter as well (if AODE/4R7x). New fluid may help, but yeah... if it craps itself shortly, it was because the clutches were worn out. If this is an AOD, tighten up the TV cable just a little and might need to look into a shift kit. If it's an AODE/4R7x, look into a j-mod.
    I know this is in the box section, but the actual car wasn't mentioned. Signature lists an aero and a box, so I'm covering all bases.
    Member tbear853's Avatar
    Jan 2021
    Virginia but I started life in Texas
    111
    change it
    Sep 2014
    Warren, MI
    6,590
    Yah, every car I've ever changed it only resulted in improvements. There was one outlier- a 1991 Mark VII. Trans shifted like ass going from 3rd to 4th anyway and unfortunately I never adjusted the TV linkage. Fluid & filter were changed- that car lost OD some three or four months later. I do not blame the fluid change- I instead point to the hard shifting. That was also an experiment- everyone says you should have more TV pressure than less and that you want a firmer shift.. but I don't subscribe to that. If the internals are stock- set it up to shift stock, least with an AOD. I've put well over 40k on the on in my '88 with zero issues.
    Nov 2020
    Olathe Kansas
    108
    You said its already slipping. So what will it hurt to change it? Sounds like its already cooked.
    1987 CV LX 5.0
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,150
    Change the fluid and filter now and start saving for a rebuild now. Maybe you can save enough before the trans quits.
    Just don't go to one of those transmission fluid FLUSH places.
    351W & F.A.S.T equipped
    Aug 2010
    Moore, SC
    515
    A lot of the ďdonít change itĒ myth is based around the notion of the fresh detergents in the new fluid washing sediment and debris from one part of the valve body to another, where it may collect and cause other issues. Thatís about as true as having bad luck from breaking a mirror.
    Iíve pulled valve bodies that have had multiple fluid changes/flushes that still had build-up in the valve body. Years ago, I bought a fox-t-bird that had 178k miles of hateful neglect at the hands of a Chevy lover. The trans fluid was BLACK and right before swapping to a T5, I decided to do a 20qt flush with a machine at work. I didnít realize how bad the trans shifted and generally behaved until I flushed it. It was like new afterward and I was even able to get a few bucks for it!
    Dec 2011
    Yonkers NY
    4,400
    I really find it refreshing that we have a bunch of people here that think logically. At least some of the time
    03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, Blue Fuzzy Dice
    Donating Member massacre's Avatar
    Oct 2011
    USA
    421
    I have heard of this over the years, but never practiced it myself.
    This story is right up there with "pack the pan full of sawdust".
    Which does work but that's a last ditch effort
