Results 1 to 12 of 12
Thread: Box Two Door Front Seat Hinges
  1. #1
    Sep 2008
    Whitestone, NY
    20,412
    Default Box Two Door Front Seat Hinges
    Looking for two door front seat hinges. Full front set...passengers and drivers side.
    79-87 should work for me from Mercury and Ford box panthers. Cannot comment on Lincolns.
    Past me or my father ripped off the lever for tilting the front seats forward and I would like to have them functioning to make tilting the seats forward a bit easier than prying up on the nub that is left with a pair of pliers.
    Below is a picture of a two door hinge next to a four door hinge.
    You can see the shiny silver nub that is left. It should be longer and have a knob attached to it.
    I am located in Whitestone NY.
  2. #2
    Sep 2008
    Whitestone, NY
    20,412
    Bump.
  3. #3
    40,850
    don' suppose you can just attach an extension to what you've got left? flat bit of metal and the sparky metal glue gun seems like it would do.
  4. #4
    Sep 2008
    Whitestone, NY
    20,412
    I have considered that as an option if one cannot be sourced. I am stuck on the fact that if I have to dismantle the seat to weld on an extension bit to whats is left Id rather just install the correct part at the time. I'd have to source a proper knob as well if I go the DIY route. Definitely an option but not the one I prefer at this point.
  5. #5
    40,850
    I don't suppose they're the same as fox parts?
  6. #6
    Sep 2008
    Whitestone, NY
    20,412
    That is a really good question...one definitely worth investigating further.
  7. #7
    Sep 2008
    Whitestone, NY
    20,412
    Looks similar but not the same:
  8. #8
    40,850
    truck parts maybe? Just seems odd that it wouldn't be shared with anything else. Its just a seat mechanism.
  9. #9
    PROUD DADDY OF JILLIAN PICKUP6772's Avatar
    Jun 2005
    MASTIC BEACH, NY
    774
    Looking at your pics, another option might be to drill and tap out the holes for a 5/16 x 2"bolt and cut the bolt heads off.
  10. #10
    Sep 2008
    Whitestone, NY
    20,412
    I do not follow. Further elaboration is required.
    My main problem is the missing tip of the knob that enables you to easily tilt the front seats forward.
  11. #11
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,150
    Just a thought. Make a junkyard run and find a two door Ford product of that vintage like a TBird. Saw off the lever and have it welded to your existing bracket. Might work well at least until you find another hinge assembly. I would get more than one at the junkyard.
  12. #12
    Sep 2008
    Whitestone, NY
    20,412
    Quote Originally Posted by Mainemantom View Post
    Yep. Will definitely be keeping my eye out for this stuff now. Sounds like it is a possible solution.
