Which Circuits Have 12v ON & START?
the typical Bosch relays are 30 or 40 amp. Should be enough for most things honestly. The connectors on those things tend to be the weak point. The cheap relay + socket packages you can find everywhere have thin garbage wire in fat insulation. Gets awful warm at the crimp with heavy load and then you have problems. I have some of those but won't run them more than about half their rated load and I don't use them for anything important. The key-on cig lighter for my phone charger can fail and it doesn't matter. Not going to trust an ECM to that.Last edited by gadget73; 10-31-2021, 07:36 PM.86 Lincoln Town Car (Galactica).
single biggest reason I like the sockets is if I have to change the relay I don't have to pay attention to where the wires go.86 Lincoln Town Car (Galactica).
And for headlight relay mods... replacing those relays on the side of the road in the dark is so much easier when there's sockets.
yeah, I've had to do that once.
If you need more than just a couple, this might be perfect for you... https://www.amazon.com/dp/B07MR64XK1/
There's a kit option that includes relays and fuses as well. You provide your own wire.
I used this style in my car because I don't care about looks and they're all over the place instead of consolidated in one place... https://www.amazon.com/ONLINE-LED-ST...dp/B01KVZ2MCW/
I have a bunch of those loose ones too, probably the same make. Not sure I'd trust running 30 amps through them but I have been running the e-fan on the Conti with one for 2 years now without any problem. I've had it running in high speed for most of that time too. Startup surge on that is probably an easy 25 amps. The original Ford relay was this really funky thing that seemed to be used on the diesel and I think a 1973 Torino wagon with a tow package. Of course you can't find that relay, so it got subbed for a generic Botch type of finest quality direct from China.86 Lincoln Town Car (Galactica).
I have the HVAC blower on one as well. Zero issues there.
Originally posted by sly View PostIf you need more than just a couple, this might be perfect for you... https://www.amazon.com/dp/B07MR64XK1/
Not sure that 14 gauge is necessarily "heavy duty" as my main circuit has 10 gauge wires. But it seems you guys are using them so i'll give it a shot. They are cheap enough lol.Last edited by massacre; 11-04-2021, 08:55 PM...
I removed the pins and uncrimped them and added 10 gauge wire for the lines I was concerned with. I think I only did that to 2 of the 13 or so I'm using. Both of those were for the blower motor relay in 2 different cars. The rest, no problems. For that short of a run of 14, just put 10 behind it and it should be fine. If not... use another one and do the terminal swap.
So it turns out the Pro-M system already has a relay for the ECM and Sensors, so I won't need to worry about the whole relay situation. Here is the relay that protects the ECM and sensors on the Pro-M harness.
I will be able to run my orange wire directly to the wire I am looking for, as it is already protected by a relay. No point in installing another relay to active this one.
I also *think* I was able to identify the two wires kishy was talking about, the Red + Light Green and Brown + Pink wires coming from the ignition switch.
I believe I was also able to track down the Red + Light Green splice coming through the firewall. This is the harness that it is loomed up to coming through the firewall.
It looks to be spliced up to another wire, but this one is Red + Green. Both greens are distinct. Here is what it looks like:
Now, my question is, which wire do I splice into to make this all work? Red + Light Green at ignition switch? Brown + Light Pink at ignition switch? Do I peel back some of the large harness the Red + Light Green & Red + Green are loomed up to and splice into that wire? Do I just splice into the Red + Light Green that is exposed already and not worry about the Red + Green right next to it?
This has really been my greatest challenge to date, and it's been really kicking my behind since February. Plus, I know my dad is getting anxious and impatient, and I know he wants to drive his car soon, and I'm what's stopping him because I'm the one doing the install. But anyways, I really appreciate the helping hand this community has given me so far. So as to not leave you guys & gals with only my troubles, here's a picture of what I have been able to succeed in so far:
Thanks again for everyone's help! Everyone here totally rocks \m/1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
