Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Which Circuits Have 12v ON & START?
  1. #21
    Mar 2010
    Lewisville, TX
    22,607
    And for headlight relay mods... replacing those relays on the side of the road in the dark is so much easier when there's sockets.
    yeah, I've had to do that once.
  2. #22
    Donating Member massacre's Avatar
    Oct 2011
    USA
    421
    Can any of you guys recommend a good socket that would handle 30 amps? Thanks
  3. #23
    Mar 2010
    Lewisville, TX
    22,607
    If you need more than just a couple, this might be perfect for you... https://www.amazon.com/dp/B07MR64XK1/
    There's a kit option that includes relays and fuses as well. You provide your own wire.
    I used this style in my car because I don't care about looks and they're all over the place instead of consolidated in one place... https://www.amazon.com/ONLINE-LED-ST...dp/B01KVZ2MCW/
  4. #24
    40,849
    I have a bunch of those loose ones too, probably the same make. Not sure I'd trust running 30 amps through them but I have been running the e-fan on the Conti with one for 2 years now without any problem. I've had it running in high speed for most of that time too. Startup surge on that is probably an easy 25 amps. The original Ford relay was this really funky thing that seemed to be used on the diesel and I think a 1973 Torino wagon with a tow package. Of course you can't find that relay, so it got subbed for a generic Botch type of finest quality direct from China.
  5. #25
    Mar 2010
    Lewisville, TX
    22,607
    I have the HVAC blower on one as well. Zero issues there.
  6. #26
    Oct 2011
    USA
    421
    Thanks for those links, i'm currently looking for singles, no room for a big box but that looks like a nice piece.
    Not sure that 14 gauge is necessarily "heavy duty" as my main circuit has 10 gauge wires. But it seems you guys are using them so i'll give it a shot. They are cheap enough lol.
  7. #27
    Mar 2010
    Lewisville, TX
    22,607
    I removed the pins and uncrimped them and added 10 gauge wire for the lines I was concerned with. I think I only did that to 2 of the 13 or so I'm using. Both of those were for the blower motor relay in 2 different cars. The rest, no problems. For that short of a run of 14, just put 10 behind it and it should be fine. If not... use another one and do the terminal swap.
  8. #28
    Oct 2011
    USA
    421
    I have terminals.
    I'll just swap the terminals, thanks!
  9. #29
    Member sluggish91's Avatar
    Jun 2018
    California
    116
    So it turns out the Pro-M system already has a relay for the ECM and Sensors, so I won't need to worry about the whole relay situation. Here is the relay that protects the ECM and sensors on the Pro-M harness.
    I will be able to run my orange wire directly to the wire I am looking for, as it is already protected by a relay. No point in installing another relay to active this one.
    I also *think* I was able to identify the two wires kishy was talking about, the Red + Light Green and Brown + Pink wires coming from the ignition switch.
    I believe I was also able to track down the Red + Light Green splice coming through the firewall. This is the harness that it is loomed up to coming through the firewall.
    It looks to be spliced up to another wire, but this one is Red + Green. Both greens are distinct. Here is what it looks like:
    Now, my question is, which wire do I splice into to make this all work? Red + Light Green at ignition switch? Brown + Light Pink at ignition switch? Do I peel back some of the large harness the Red + Light Green & Red + Green are loomed up to and splice into that wire? Do I just splice into the Red + Light Green that is exposed already and not worry about the Red + Green right next to it?
    This has really been my greatest challenge to date, and it's been really kicking my behind since February. Plus, I know my dad is getting anxious and impatient, and I know he wants to drive his car soon, and I'm what's stopping him because I'm the one doing the install. But anyways, I really appreciate the helping hand this community has given me so far. So as to not leave you guys & gals with only my troubles, here's a picture of what I have been able to succeed in so far:
    Thanks again for everyone's help! Everyone here totally rocks \m/
    1985 2-Door
    CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
