PHP Warning: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead in ..../includes/class_bootstrap.php(433) : eval()'d code on line 106
Hard to Start 2000 MGM Only When Cold - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Hard to Start 2000 MGM Only When Cold
  1. #21
    Goal was 'giving back', done by 2020.
    Jul 2014
    Canada
    2,190
    You're the electronics expert, so your guess would be better than mine. I have no idea what thermistors are made of or how they are made, but it seems they are destined to fail in a certain direction. Dunno if that is deliberate or just the nature of the beast.
  2. #22
    Jul 2014
    Canada
    2,190
    I'm having unbelievable bad luck with this issue. Rather than try another local Ford sensor, I went with an aftermarket sensor from the U.K., and it measured defective too. Here are photos showing the readings from two different meters:
ID:	58542Click image for larger version.
ID:	58543Click image for larger version.
ID:	58544Click image for larger version.
    That one and at least two of the Ford ones had relatively recent dates, so degradation over time seems to be ruled out. Maybe I'll have better luck with a part from China.
  3. #23
    Mar 2010
    Lewisville, TX
    23,606
    I see... you need to measure pin to pin, not pin to case. Pin to case is only for the single wire sensors.
  4. #24
    Jul 2014
    Canada
    2,190
    Apparently not. Most, if not all, of the prior sensor readings were done pin to pin, and I started doing pin to case at some point with the same result. Doing pin to case was easier for photographing, and I just confirmed that the result is the same for pin to pin. The only thing I can think of at this point besides some kind of widespread manufacturing defect is having some kind of magical force field around me that causes coolant sensors (but not my air filter box sensor) to read bad.
  5. #25
    Mar 2010
    Lewisville, TX
    23,606
    Wait... you have the meter on 200K ohm setting. This means that is reading 19K to 23K (depending on meter). I know a LOT of meters that don't move the decimal point properly on this one setting. It's very confusing. And if it is the case that it's over 20K (OL or -1 on 20K setting), this is close enough. Remember... these sensors are not very accurate. They can vary +/- 15% and be perfectly serviceable.
    Now, this range is very broad on closed loop settings. If you boil some water and measure it after a brief soak (leave the electrical out of the water as much as you can for ease of use), it should be less than 3 ohms. You need to account for the wire resistance of the meter at this point as well and subtract that from your reading. If it's not around 3K ohms and remains in the 20K ohm area, you indeed have a bad sensor.
  6. #26
    Jul 2014
    Canada
    2,190
    I had confirmed some of the readings at a lower setting, and the first defective sensor was confirmed with my scanner reading the PCM, so I doubt it's a decimal point issue. Also, I tried that latest sensor in the fridge and freezer and did get higher resistances, but even in the freezer it was only about 40kohm, which shows on the chart as being well over 10 degrees C. The U.K. seller provided a refund without requiring me to send the sensor back, so I will take the plastic off and try it in boiling water for the helluvit. I've ordered one from China, and if that one doesn't work out, I guess I'll try a U-pull yard.
  7. #27
    Mar 2010
    Lewisville, TX
    23,606
    Bah. Yeah. That's amazingly bad luck with parts. If the china one doesn't ring out with the meter, I'd be tempted to just try one you have on hand and see if it works.
