Results 1 to 11 of 11
Thread: Dropped a Screw in the Defrost vent
    Aug 2019
    Portland, OR
    125
    Default Dropped a Screw in the Defrost vent
    Thought I could do one of the dash pad screws without my magnet. Dropped it down the passenger side vent. Does anybody know where they drop down to and if it will mess up the distribution doors or fan blower?
    Just as I was buttoning up my NOS temp sensor too...
    What a Luxury car should be. mercurygm88's Avatar
    Jul 2011
    The Firelands
    1,617
    Quote Originally Posted by kellen302 View Post
    Not sure where it all ends up. I dropped a 10mm socket and extension into the dash of my Ď02 back in 2019. I never found it and Iíve never heard it rattling either.
    Jan 2008
    New Jersey
    3,234
    It's probably in the heater core box. I found 2-3 screws when i replaced my heater core. you could try to fish it out with a magnet, but chances are you wont get it back
    41,000
    It goes to the same place random socks and 10mm sockets go.
    GMN Regular WagonMan's Avatar
    Bridgewater Ct.
    860
    Just today i pulled 3 screws out of my defroster ducts with a small flat magnet on a string. I installed a dash cap on my Colony Park a few days ago. I made sure not to drive the car until I found a magnet small enough to fit down the duct. I didn't want them rolling into a space i couldn't reach with the magnet. WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
    20,496
    Cheap extending magnet stick worked for me when this happened one. Magnet on string is nice idea too. There is some hope in finding it. I was PISSED when I dropped the screw. Totally believed I would not recover it.
    41,000
    I dropped one in the Continental's vent, stuck a magnet down there and got a different screw that someone else had dropped. Don't think I found the one I lost but the other one did the job.
    Aug 2019
    Portland, OR
    125
    I was at a friend's shop so i had to drive it home that night, Might try the magnet on a string though. I tried several different magnets on a stick and a bore scope but couldn't find it.
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,218
    I have had that happen with the screws falling into the abyss. I don't bother hunting for them. Just find another. I try to use a screwdriver with a magnetic end. Really helps.
    22,746
    Hence the reason I showed the trick of using the magnet on a stick WHILE using the magnetic screwdriver on those vent screws in the Coverlay ABS cap install thread.
    http://www.grandmarq.net/vb/showthre...l=1#post799281
    Aug 2019
    Portland, OR
    125
    Sly, that's what I usually do for these ones, but I thought I was steady enough to do the last one without it, because I'm an idiot. Also my dash pad is some vinyl wrapped fiberglass custom thing done by a previous owner, not the ABS piece it should be. The fit/alignment is meh
