Results 1 to 8 of 8
Thread: Power Steering Line Dilemma
    Member sluggish91's Avatar
    Jun 2018
    California
    119
    Default Power Steering Line Dilemma
    Hello to all my fellow Grand Marquis owners. I am faced with a dilemma on my 85 Grand Marquis.
    My high pressure hose started leaking. I removed it and located a small rip/hole.
    I purchased an Edelman 71044 high pressure hose from RockAuto. All hoses on that site seemed to have the same stock photo.
    It arrived and it was not the right thread pitch on the pump side.
    In fact it looked entirely different.
    So I went to my local auto parts store and unfortunately they had the exact same hose that I got on RockAuto, which wasn't going to arrive for another few days and was 3 times the price of the one on RockAuto. Forget about it. Fail.
    No big deal, I told them to bring out a power steering pump they had in stock. My RockAuto line wouldn't thread into the pump. Fail.
    In my years of ownership I have never replaced the pump.
    For now I just mickey moused it, cleaned the line as best as possible and smeared some gasket maker on there, then wrapped it with some tape. Its super ghetto but as long as there isn't power steering fluid being flung all over my engine bay I'm ok for the time being.
    Could it be that the previous owner replaced the pump and line with something of a different year?
    Does my original power steering hose look like the right one?
    If someone has any recommendations on what I can do, I am open to suggestions.
    Thank you.
    1985 2-Door
    CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
    Dec 2019
    Fort Irwin, CA
    242
    As luck would have it, I happened to have that exact hose sitting in the trunk waiting to be installed. So I went out to the garage and took it out to compare with the current, probably original hose.
    Edelman 71044 High Pressure Hose, fresh from Rock Auto:
    Here it is beside the high pressure line currently installed on my car:
    I also happened to have a reman power steering pump from O'Reilly, which I was able to thread the Edelman line into:
    So I think the 71044 hose should be correct, though it's strange that it wouldn't thread into the store's pump either. My service manual shows the Ford CII pump as being common across all Panthers in '87, though the non-Police Fords and Mercuries (Mercurys?) are listed as pumping slightly less than the Police package variants and Town Cars. Perhaps '85s had some variety in which pump was installed, or as you say a previous owner might've swapped it over.
    I don't know enough to give you a definitive answer, but these pictures at least show you what I'm working with. Hopefully that's somewhat helpful.
    6,560
    Sluggish91 - there is a separate part currently screwed onto the end of your current hose. Get a wrench on it and a wrench on the hose fitting and they will unscrew from each other. I think that's some kind of regulator that basically lets them use the same pump on many applications by varying the power assist.
    GMN Regular Giraffe's Avatar
    Jan 2016
    Cabot, AR
    1,079
    Tiggie is correct. I had to remove this piece when I replaced the pressure hose on my '90 GM. Two wrenches is all you need.
    óJohn
    1985 Ford F-150 XLT Lariat
    Donating Member massacre's Avatar
    Oct 2011
    USA
    461
    Good eye
    Birdsboro PA.
    17,799
    the pump fitting is still attached to the old power steering hose.
    Jun 2018
    California
    119
    Thanks guys, I completely overlooked that small detail! I'll get to wrenchin & report back with my results.
    1985 2-Door
    40,966
    change the O rings on the pump fitting before you put it back on otherwise its probably going to leak.
    No better time to change the body O ring either if thats leaking.
