1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, Race Crank Pulley, Bilstein Rear Shocks, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Motive 4.30 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, ASP Crank Pulley, Jegs Built AOD, 3000 Stall Converter, Ford Racing 4.10 Gears
