Bumper shock?
    Bumper shock?
    What’s inside bumper shocks want to powder coat them
    I think a large spring It shouldn't have any energy when those are pulled apart. Either that or it's more a sealed nitrogen style shock. I've never managed to disassemble one yet, but I've heard stories about bumper shooting off when the car is on fire, so I'm leaking towards the gas piston idea.
      No gas in your shock Jack. It has some sort of membrane that holds the shock extended. Once the membrane is pushed in, the shock is basically toast. I have pulled some out and they stayed out, and some are loose and won't stay out. WagonMan
      89 Colony Park
      90 Colony Park
      70 HEMI Daytona Convertible
        What is the membrane made of? It has got to withstand around 450 degrees!
          Thanks for info
            The one you knocked back out on my car stayed out until the car was disassembled. I'm pretty sure I still have it floating around somewhere in the garage. I suppose if they're loose after, you could always hit it with small a weld or something to hold it in place.
              450 degrees??
                I don't know what the membrane is made of, possibly plastic? I guess 450 degrees is what you have to bake the powder coated parts at? WagonMan
                89 Colony Park
                90 Colony Park
                  Originally posted by Brown_Muscle View Post
                  450 degrees??
                  Yes. More often then not around 450 till flow out then back down to 400 for ~20 minutes. Depends on manufactures directions of powder.
                  Doesnt hurt outgassing the part at that temp for ~30 minutes just to be sure all oils are baked out of it before you start the powder coating process.
                    I need to look when I get home, I may have some sacrificial bumper mounts we can dissect to find out. They would be the old ones from my 93's previous front bumper.
                      My recently acquired '88 Colony Park has a squished in front bumper on one side. From reading this, I should be able to just pull it out and use something to just fix that now-ruined shock in place? Do they sell replacements anywhere?
                        I used 6 x 6 x 15" block of wood to bang out SLACK'S front bumper. It popped out far enough to look good. Once in a while NOS ones pop up on E-bay. They are not all the same! Different lengths and the cylinders are different widths. According to my parts book, 88 does not interchange with any other year. WagonMan
                        89 Colony Park
                        90 Colony Park
                          I like the idea of smacking it out and fixing it back in position. Years ago I owned an e28 BMW 528e with the horrible protruding US bumpers. I drilled holes in the shocks, drained the fluid, pushed the bumpers in and threw screws in the shocks to hold them in place. Had to modify trim to suit.
                            Late to the party for the "what's inside" topic, but I cut through one (89 Town Car) in the junkyard with a recip saw (a trick I learned from the derby folks) and can tell you it's full of a firm gel. It makes quite the mess when the saw blade shreds it.
                            This sharply contrasted against the 76 New Yorker I gave the same treatment to, which was full of bad smelling liquid oil with coil springs.
                            Current driver: wagon
                              New Yorker sounds like it had true 5mph bumpers.
